Rear Trackbar
Old Sep 19, 2013 | 07:52 AM
leaky10's Avatar
Default Rear Trackbar
If i run a rear adjustable trackbar do i still need the relocation bracket?
Old Sep 19, 2013 | 07:58 AM
AlexjeepVb's Avatar
Nope. Its one or the other, rear adjustable track bar way better choice.
Old Sep 19, 2013 | 08:15 AM
TheDirtman's Avatar
Actually if you raised the rear track bar on the axle side by the amount of lift you have would be a better route to go over an adjustable on the factory mount. By raising the mount you will raise the roll center making the jeep more stable in off camber situations. A new weld on track bar bracket can be installed in the proper location for your lift size as well and if done right will be much stronger then the factory bracket.
Old Sep 19, 2013 | 09:20 AM
JKred's Avatar
Originally Posted by TheDirtman
Actually if you raised the rear track bar on the axle side by the amount of lift you have would be a better route to go over an adjustable on the factory mount. By raising the mount you will raise the roll center making the jeep more stable in off camber situations as well as handle/corner better on the street. A new weld on track bar bracket can be installed in the proper location for your lift size as well and if done right will be much stronger then the factory bracket.
Besides what I added in red Dirtman said it all.
Old Sep 19, 2013 | 10:32 AM
leaky10's Avatar
Thanks for the advice
Old Sep 19, 2013 | 11:28 AM
TJJK's Avatar
Done both here- teraflex axle mount bracket and JKS bar. 4WD PARTS is "giving away" and discontinuing JKS line because of their relationship with new JKS parent company.
Old Sep 19, 2013 | 01:46 PM
cgn152's Avatar
Of course I find this thread this afternoon! I just had my 2.5" teraflex w/ fox 2.0 shocks installed today. I also grabbed a front and rear tflex track bar. The instsll guy talked me out of installing the bracket since I had the adj track bar. He told me he had seen similar brackets break off of mall crawlers. Now I'm thinking I'll put the bracket on myself. Thoughts?
Old Sep 19, 2013 | 01:58 PM
nthinuf's Avatar
There are different kinds of brackets available. Some reinforce the weak stock bracket, others just apply extra leverage on the already weak welds. Since the Tera bracket has a ubolt going around the axle tube, I doubt it is one that your installer saw rip off.
Old Sep 19, 2013 | 03:34 PM
cgn152's Avatar
Default Thanks, Think I should throw it on there?
I having it aligned tomorrow. I may just ask them to throw it on there while its there. Side Bar where in CO are you? I hope you haven't been affected by the torrential rain. Im originally from there CO Springs, but Vegas is where the work is. thanks!
Old Sep 19, 2013 | 03:46 PM
nthinuf's Avatar
East side of the Springs, wasn't directly affected by any of the floods or the fires. We've sure had our share of weather related fun over the past two years.
