Rear Trackbar
Old May 20, 2009 | 05:44 AM
hohokom's Avatar
Default Rear Trackbar
I purchased a rear trackbar and had a couple of questions. When I did my lift, everything worked out well. I was told when I had the alignment done that I might get a rear trackbar so in the future I would have no problems with getting the rear axle in alignment.
I am ready to put this on, but it would seem I could just put it on exactly like the stock one, with no adjustments. Do I do that with the unit lifted so the axle is off the ground?
Any suggestions would be appreciated.
Old May 20, 2009 | 05:48 AM
HappyCurmudgeon's Avatar
Eternal ***erator
I put mine on while on the ground, it was easier to get the bolts in with a friend pushing the side of the Jeep.
In my case, my friend was a load strap I simply adjusted to get the Jeep roughly centered over the axle, then once i was happy with it, I just adjusted the trackbar to fit the distance between mounting points, stuck the bolts nuts on and torqued it down. (dont forget the big nut on the adjuster)
It still needs a minor tweek, but no one would see it but me.
Old May 20, 2009 | 05:53 AM
mkjeep's Avatar
http://project-jk.com/images/writeup...b/DSC06407.jpg
Put it on jack stands and put a floor jack underneath the pumpkin and use rachet straps to get it to line up, depending on your lift is the amout you'll have to adjust. On your lift now do you have a drop bracket or axle brkt or no brkt at all?
Old May 20, 2009 | 05:59 AM
mkjeep's Avatar
Damn , HC, beat me to it, you could do it his way too. I had an axle bracket , so all I had to do was lenthen mine to mount on the stock mount versus where it was on the bracket with the stock TB.
Old May 20, 2009 | 06:05 AM
seer1's Avatar
I used a floor jack and pry bar to get the holes to line up instead of a ratchet strap. The strap is probably easier.
Old May 20, 2009 | 06:09 AM
Eternal ***erator
I was working solo, so i had to use what was available, coulda used a few more arms a few times putting the lift on, this was one of those times, but it all worked out.
Old May 20, 2009 | 06:40 AM
JK Rocker's Avatar
Glad I saw this. I will need to do this soon, too.
Old May 20, 2009 | 06:51 AM
hohokom's Avatar
Default Thanks
JUST WANTED TO SAY THANKS TO ALL THOSE WHO RESPONDED TO MY TRACKBAR QUESTIONS. NICE TO HAVE PEOPLE AROUND WHO CAN HELP WHEN I HAVE QUESTIONS LIKE THIS.
