rear trackbar bracket
I guess I didn't read his question carefully. Now the question should be why do you want a bracket for your rear trackbar?
i have stock trac bar wth drop down braket from frame. i had heard even wth the adjustable bar to use a braket but the one that mounts to axle. im asuming because thd stock location is crap. oh yea 4.5 in lift wth 37s if that maters. im just folowing some advice from other jeepers. but if i dont need it or wil not make a diference then i wont get it.
thats a reinforcement bracket, so the stock doesnt get ripped off or broken, I am trying to beef everything up after I saw a XJ get his control arm ripped off just hitting a deep hole
Longer adjustable bars, no matter how good the quality is, used without bracket that raises from the axle cause problems. As the axle is stuffed the and the angle of the trackbar goes closer to level it pushes the axle sideways to the left. If you were centered you're not any more and it could cause contact issues.
The RE 3.5" I bought 11 months ago had the axle bracket as does their Long Arm Lift. Earlier versions of both used frame drops. From what I saw at EJS TeraFlex still uses frame drops and when I asked nobody could give me a coherant reason why. Clayton uses an axle bracket. We've learned a lot about the JK over the past 3 years; maybe not everybody is up to speed.
