Rear upper control arm passenger side bolt access
Old Aug 18, 2016 | 07:05 PM
matt852's Avatar
Default Rear upper control arm passenger side bolt access
Anyone know how to get the driveshaft side of this bolt on a 2 door do I have to drop the gas tank?
Old Aug 18, 2016 | 07:15 PM
karls10jk's Avatar
It should be just like the driver's side where it's a flag nut inside the frame and you unzip it from the outside.
Is it not?? (Added pic)
Like this vvvvv
Old Aug 18, 2016 | 07:46 PM
matt852's Avatar
It should be just like the driver's side where it's a flag nut inside the frame and you unzip it from the outside. Is it not?? (Added pic) Like this vvvvv
I see could see it, would you recommend me using my finger to hold that piece while I I tighten it so it doesn't fall into the frame?
Old Aug 18, 2016 | 07:57 PM
Jahamm88's Avatar
The frame will hold it in place. It should rotate then the "flag" will catch on something allowing you to remove the bolt
Old Aug 19, 2016 | 04:43 AM
karls10jk's Avatar
^^ that all day. It'll get probably 1/4 turn each direction before it catches on the frame and you're set. To reinstall, just hold the bottom of it and fish it into place, turn just until it starts the bolt then get after it with your ratchet and torque wrench.
Old Aug 19, 2016 | 05:10 AM
jadmt's Avatar
JK-Forum Ambassador
Ever see the photo that was floating around here of the guy's finger when tried to hold the flag nut while using his impact wrench? Ouch
Old Aug 19, 2016 | 05:29 AM
Jahamm88's Avatar
Default really?
that doesnt sound like it ended good....i guess darwin was right
Old Jan 3, 2026 | 04:52 PM
Enough to get me in troub's Avatar
All yall had to do was use a bottle jack on the exhaust in the middle. Where it runs to driver side. Bolt pops right out i did it today. Bushings on the other hand are a completely different beast.
