rear upper/lower adjustable control arms
Old Sep 29, 2010 | 05:10 PM
DeepH2OBlue's Avatar
Default rear upper/lower adjustable control arms
Got a 2010' unlimited with a 4" lift on 35's. The dealer did the lift when i bought it. The lift is a Rough Country so they use the OEM control arms. The front is fine but the rear tire is not centered in the fender opening (sits forward) and drives me nuts so i want to correct it. I think i need both the upper and lower adjustable control arms. What is a good brand to get that is fairly inexpensive?
Old Sep 29, 2010 | 08:55 PM
Any help guys...thanks
Old Sep 30, 2010 | 12:31 AM
aermotor's Avatar
Get the Rough Country brand adjustable arms, WAY cheaper than anything else and get the job done just fine. You'll want them anyway when you decide to upgrade your shafts. They are about $195 per pair shipped. I think from what I've read the best is to start with front lowers and rear uppers.
Old Sep 30, 2010 | 02:54 AM
Strutssound's Avatar
I just got the Rock Krawler upper and lowers. SOLID steel 1 5/8" lower; Solid 1 1/2" upper, way way heavy. best part is they move the rear axel back 1" so no pinch weld or Rubi Rail issues. Not cheap but the good stuff rarley is.
