Rear wheel squeek
Old Oct 2, 2013 | 02:31 PM
mikead40's Avatar
Default Rear wheel squeek
2013 rubicon <10kmiles
After a weekend of wheeling, I noticed my passenger side rear wheel has developed a squeek. Best way to describe it: it sounds like a cricket. It corresponds to wheel speed, can't be heard above 50mph, gets slightly louder when light pressure is applied to the brake petal, and completely goes away with full brake petal pressure. I took the wheel off - the rotor seems straight. I cleaned any dirt/mud from around the brakes, but being that I'm relatively new to this and have no previous mechanic experience I wasn't going to go beyond that. Anyone have any thoughts?
Old Oct 2, 2013 | 03:00 PM
kjeeper10's Avatar
Vet Army
Any off roading? Worst case bent flange. Pull tire and watch for runout.
Old Oct 2, 2013 | 05:16 PM
OH9JK's Avatar
JK-Forum Ambassador
Yep sounds like mine...bent axle shaft flange.
Old Oct 2, 2013 | 05:40 PM
JK yeti's Avatar
I thought my squeak was due to a bent axle flange but it turned out to be that my caliper slider pins were not greased and cause an annoying squeak!
Old Oct 3, 2013 | 09:36 AM
SOCAL-JK's Avatar
I have the exact same squeak issue that you described. Last night I raised my Jk and watched the tires spin-looks like I have a bent axle shaft
Old Oct 3, 2013 | 10:10 AM
vulcan classic's Avatar
Same here. Annoying squeak with light brake pedal and goes away with full braking; I pulled my pads and applied grease where the pads slide in the calipers and squeak is gone, thanks to tip from other forum members, worth a shot.
Not just in the pins but where the pads are seated in the caliper casting, also put some lube behind the pads where they contact the piston.
Sent from my iPhone using Tapatalk - now Free
Old Oct 3, 2013 | 10:14 AM
Doing this at every tire rotation and no more squeaks
Old Oct 3, 2013 | 10:24 AM
SOCAL-JK's Avatar
This is worh a shot, thou when i raised he JK i noticed theirs a wobble on my rear passenger which is where the squeak comes from
Old Oct 3, 2013 | 10:28 AM
You'll know, a bent axle flange is pretty obvious when you take the wheel off and spin the hub
Old Oct 3, 2013 | 11:43 AM
Maertz's Avatar
Agreed. mine i just jacked the wheels up both the rear tires wobbled like hell.
