Recenter steering wheel required after leveling?
Old Mar 11, 2012 | 02:02 PM
Footbraker's Avatar
Default Recenter steering wheel required after leveling?
2" teraflex leveling kit, 2011 unlimited. Will the steering wheel need to be re centered?
Old Mar 11, 2012 | 02:04 PM
Robar's Avatar
Probably a little bit.
sneck's Avatar
probably, but considering you don't do it till after everything is put back together, do the lift first then see
Old Mar 11, 2012 | 04:53 PM
bigf350sd's Avatar
It more than likely will. Very simple, though. Loosen the two 15 mm nuts on the drag link (connected to pitman arm) and have someone watch the steering wheel as you turn that collar where you loosened the nuts, until it's straight, and to tell you if you're going in the right direction or not. shouldn't take but a turn or two to get it right.
Old Mar 11, 2012 | 05:05 PM
tbone in tx's Avatar
I put the TF leveling kit on yesterday and do need to recenter but I haven't done it yet.
