Recommend a 4" lift....
Zone < Rough Country < stuff we leave in a toilet.
$600 for a 4" lift probably means more of a basic kit that may cut some corners and not address some of the issues caused by lifting that much.
If that makes you happy, ignore everyone and go for it. The rancho 4" should be around 800 (without shocks). So that one is out. How about the Rough Country 4" ??? Drop pitman and frame-side trackbar bracket, cam bolts, integrated bumpstops, all for only $500. Or the zone lift you mentioned, cam bolts, no steering angle correction, coils and shocks that you can find some reviews on in other threads here.
I went with a heavy duty ome lift you can get 4 inch Ed easy heavy springs can handle the weight my warn bumper without the winch is 155 lbs not sure what my smithy 10 k winch and steel line isn't light
I would consider just doing necessary componets vs. a full on kit, maybe I'm just a fan of the frankenlift idea.
I'm going with Evo 4" coils, Bilstein shocks, Synergy adjustable arms and steering and bracketry. Also consider drivelines etc. at 4"
It is all doable.Take some time and do the research look for specials from our vendors.I'm doing 4" upgrade right now,when done i've will have spent just under 2k for everything leaving me room for some new wheels
