Redneck Ram - OD dimension needed!!!
Hi guys
Just installed their hydro-assist and new box last night. Steering is super slow and stiff - I'm thinking I got the wrong ram in my kit. Can someone please measure there's for reference? Mine measures 1.9" (outside diameter). Not sure if this is correct for a 1.5" bore.
Didn't want to mod pump before I confirmed I have the right ram.
Thanks!!!
Thanks!!!
I believe mine is 1.5"x6" my pump is not modified. The steering is a little slow at low speed, about the same as stock feeling. I don't have a digital caliper so 1.9 " seems close...mine looks to be 1and 7/8"
Hi guys
Thanks!!!
Thanks!!!
Perhaps you need to bleed the system more? I know I had to cycle my steering system lock-to-lock like 20 times, then fill, then cycle, then fill. Then I had to take it up and down the road several times and fill. All good now
One word of caution that will help prevent an ungodly fluid mess. If you rack the steering with the reservoir cap off the fluid will overflow and pour all over the harnesses, etc. I tape the neck of an oil fill funnel to the reservoir opening, which will allow the fluid to rise up into the funnel and then recede wthout blowing all over the place.
Another bleed procedure that a guy showed me. Should the air be stubborn, try cracking open the lines at the reservoir slightly and start the engine. Allow the fluid to leak out into a drain pan and it will eveacuate any air trapped in the ram. Keep an eye on the reservoir and keep it topped up.
Hope this helps!
I bled the crap out of it - hours one day. Must have went back and forth 75 times. Not more bubbles - but I did have a fat mess from it over flowing a few times as mentioned.
Steering was still slow and stiff. It didn't get better with throttle either which is opposite of what everyone has said. I was stumped and frustrated.
I called matt at WTO and he said it sounded like the bypass valve was stuck open. I pulled piston and spring out of the pump. Cleaned it, hit with some scotch bright and put it back together. Did a quick bleed and now all is good!!! I can turn it quick, it responds like it did before and is better when I blip the throttle. Even put it in 4-lo and locked the front axle. Couldn't even tell! Can't wait to go back to Moab this fall - gonna be a different trip.
Now I just need to figure out the hose routing
Yeah... I learned this the hard way. Make sure you check the hoses under the following conditions and with the steering wheel locked all the way left then all the way right.
Both front tires compressed into the fender wells.
Both front tires drooped.
Driver compressed, passenger drooped
Passenger compressed, driver drooped.
I thought I had mine good and then damaged one hose.
