Regeared the 2 door- 4:10's-5.13's (6 Speed) Superior Axle..
Old Apr 22, 2007 | 04:56 AM
Piginajeep's Avatar
Default Regeared the 2 door- 4:10's-5.13's (6 Speed) Superior Axle..
I got my jeep back lastnight, I figure I would post, I havent heard of any two door guys regearing to 5:13's
My stock Gearing was 4:10''s with the 6 speed.
I'm now regeared to 5.13's. I can say It has alot more power. Its been 3 months since my tire upgrade, but it feels faster than stock. Its actually really fast.
My only goals were to get the acceleration back at highway speeds and to be able to use cruise control again. I got that back and then some at highway speeds, (70-75mpm)
My only concerns was the RPM's at cruising speed, which for me is about 75 mph on the highway. Its a bit higher than I like. at 75 mph. its sitting aroudn 3,000 RPMS, Which actually isnt that bad.
It'll be perfect when I upgrade to 37's down the road, But its definetly liveable. I cant thank my mechanic enough, he did a good job and was very helpful and gear selection.
Old Apr 22, 2007 | 05:26 AM
cablerep79's Avatar
Thanks for the info. Just to clarify, are you seeing the 3000rpm at true 75mph or at what your (incorrect) speedo is showing to be 75?
Also, for the guys that are running 4.88 with 6-spd and 35's, what rpm's are you running at true 75mph?
Old Apr 22, 2007 | 06:29 AM
Piginajeep's Avatar
the speedo is showing 71-72 mph. at around 3,000 RPMs. So its around 75 mph...
Old Apr 22, 2007 | 06:41 AM
wayoflife's Avatar
JK-Forum Founder
Hey Piginajeep, glad to hear you went 5.13's. Hell of a lot more power than stock if you ask me and the RPM's may be a bit high but as you said, not that bad... maybe a couple hundred at most.
Now all you've gotta do is find an excuse to get up on 37's
Old Apr 22, 2007 | 07:27 AM
Evolution's Avatar
Sponsoring Vendor
I have sold a lot of 5.13 with 35s
it is a win win. More power now, The new 3.8 likes to rev high, and you have room to grow to 37s.
Old Apr 22, 2007 | 07:42 AM
edstroyer's Avatar
What are the RPM differences with the Overdrive On/Off?
Old Apr 22, 2007 | 07:58 AM
Evolution's Avatar
Sponsoring Vendor
The rpm diference between overdrive on and overdrive off
will be the same as stock with any axle ratios.
Old Apr 24, 2007 | 02:03 PM
Superior Axle's Avatar
Sponsoring Manufacturer
That is GGRRRREEEEAAATTTTTT!! Glad to here everything went well.
Mike
Old Apr 24, 2007 | 03:22 PM
MBAR741028's Avatar
I am having my 4.88's installed this week I will post those #'s once its completed.
Old Apr 24, 2007 | 03:30 PM
Piginajeep's Avatar
Mike
How could I forget, thanks for making the gears!!! My wife says it's doing really welll for her on the highway. She drives it more than me...
