Regeared 3.21 axles???
Old Apr 17, 2007 | 02:54 PM
MBAR741028's Avatar
Originally Posted by 2K1TJ
I'm with ya. MY 4.88's were just delivered a few minutes ago. I'm going to the dealer in a day or 2 and pick up what I need (or at least what I thnik I need that I got from another thread). I'll see If I can find the link.
Edit: Here's the link
I went to the dealer today and got the prices for everything in the write up including pinion bearings. This should be everything. See below
part #
front
4720895 Pinion nut 13.00
68004072-AA crush seal 26.70
5066047-AA spacer 12.30
4856368 shim kit 34.00
J8126499 pinion bearing 66.20
rear
5191197-AA Pinion nut 1.20
68003265-AA crush seal 33.40
5183525-AA spacer 1.30
4746979 pinion bearing 67.60
Old Apr 17, 2007 | 03:20 PM
2K1TJ's Avatar
Thanks for doing some homework for us. The writeup didn't mention a crush seal. Maybe it's an "iffy" part, just depends on if you damage the old one when removing it. Same w/ the pinion bearings I guess. Those are more $$$ than I was expecting.
Maybe it's worth mentioning, I read once in an article by Bill Vista that he recommends not re-using the ring gear bolts. Anybody else heard of this? I guess he knows his stuff. I'm gonna check on prices for those. If they're reasonable, it's a no-brainer.
Old Apr 17, 2007 | 03:22 PM
2K1TJ's Avatar
So that's roughly $152.20 for the front, and $149.20 for the rear. As always, I was hoping to get off cheaper.
Old Apr 17, 2007 | 03:53 PM
MBAR741028's Avatar
The article calls it a crush sleeve dealer called it a crush seal. Dont know about the ring gear bolts?? Why dont the rig and pinion kits come with bolts!!
Old Apr 17, 2007 | 10:34 PM
2K1TJ's Avatar
You sure about that? Here are the part #'s for the crush sleeves, as copy/pasted from the write-up:
Front Crush Sleeve (5183525AA) $1
Rear Crush Sleeve (5066047AA) $10
Those are different #'s from the crush seals, as you can see. Could the crush seal be the same thing as a pinion seal?
Not sure about the ring gear bolts either. I'll open the boxes when I get home. Maybe I'll get lucky and they'll be included.
Old Apr 18, 2007 | 04:54 AM
MBAR741028's Avatar
I am confused about the crush seals I think the parts guy wrote the wrong name next to the part #'s. I do have those part numbers listed.
Old Apr 18, 2007 | 05:33 PM
MBAR741028's Avatar
I ordered the parts today they had half in stock and had to order half. Should be in by Tuesday. I am set up to have them installed Thursday. I will keep you posted....
Old Apr 19, 2007 | 01:27 PM
luisjg's Avatar
hi guys.
i used to have a tj with 3.07 it wasnt fast on the highway but i was running 33 x12.5 and i realy didnt care ,,i loved the thing..
anyways,, I getting a 4 door jk thats has 3.21 ,,,so i will be installing 33 x11.5 tires,,,
will it realy suck?
i mean compare to what i had in my tj? if its the same its ok like I sed before i didnt care. i guess my question is will it be worth,,? because im guessing not since its 3.21 inted of 3.o7
Old Apr 19, 2007 | 01:37 PM
MBAR741028's Avatar
like I have said I have 35's and the 3.21's its not as bad as you think.
Old Apr 22, 2007 | 12:48 PM
2K1TJ's Avatar
Any updates?
