Regearing
Old Apr 9, 2008 | 08:45 PM
high-octane's Avatar
Default Regearing
Hey guys, got my lift and tires on. Im going to regear now. I called the shop and the guy i talked to said i needed a new carrier for the front (dana 30). Its a x model. Is this true? What are you guys paying for 5.13's? One more thing, he said if i wasnt feeling any vibes i shouldnt worry about drive shafts. Its a FT 3" econo lift. Thanks for any help.
Old Apr 9, 2008 | 08:55 PM
nukeman's Avatar
What gears do you have right now? If you have 3:21's, then yes, you will need a new carrier for the front D30. If you have 3:73's, then you won't need to change the carrier.
I paid $1224.00 for parts, labor, fluids, warranty. That's a little on the cheap side. Normal price runs anywhere between $1200-$1800 depending on your area, shop, etc.
Old Apr 9, 2008 | 08:57 PM
I have 3.73 now. He quoted 1600.00. He may have been confused on what gears i have now.
Old Apr 9, 2008 | 09:06 PM
TEEJ's Avatar
Talking
Yeah - 3.73 is the cut point...3.73 and up use the same carrier.
For a 3" on a 2 dr....yeah, you might be ok on the drivetrain...but you're at the cusp.
BTW - when you re-grear - and the diffs are open..THAT"S when you want to throw a locker in...all the labor is already being done to re-gear.....so, its just adding the cost of the lockers them selves.
At least ONE locker if you can swing it.
Old Apr 9, 2008 | 09:51 PM
Cool. Any suggestions on lockers?
Old Apr 10, 2008 | 04:04 AM
MAROONJEEP's Avatar
I went with an arb air locker in the rear just because my limited slip had some chipped gears in it and they said it would eventually go. I haven't used it yet but im pretty excited.
