Regearing JK Rubicon
Old Sep 29, 2009 | 01:07 PM
backup's Avatar
Default Regearing JK Rubicon
Hi. I want to regear my JK Rubicon with 5.13 gears. I haven't found a webshop that has offered both rear and front gearings and overhaul kits. Any suggestions?
Can I use the same overhaul kit front and rear? I have understood that the Rubicon gearings are diffrent, compared to stock D44 gearings.
Stein, No(r)way
Old Sep 29, 2009 | 01:12 PM
07rubisteve's Avatar
You can get them from Northridge4X4, Quadratec and a few other places.....check them out, they have everything you need to get it done...complete overhaul kits, or basic install kits...depends on your application....ie amount of miles on your rig.....
I just went to Superior 513 in mine.....I love it...to me the mod is completely worth it...specially if you have 35's or larger.....cheers
Old Sep 29, 2009 | 01:21 PM
nthinuf's Avatar
You can order them from any shop, but here is the link to the gears at Northridge, since I had it handy.
http://www.northridge4x4.com/products.php?cat=277
Select one of the front/rear packages, and there is a pulldown for you to enter which model you have so you're sure to get the right gears for your Rubi.
It might be a bit on the costly side for you to call them, but they are a sponsor here, so you can send a direct message to get more info if you need to.
Old Sep 29, 2009 | 01:35 PM
stangjeeper's Avatar
Call Dave at Northridge. He has what your after.
Old Sep 29, 2009 | 01:37 PM
nthinuf's Avatar
He lives in Norway, don't imagine he'll be calling...
