regearing vs performance mods
Old Oct 29, 2011 | 01:26 PM
jpkjk's Avatar
Default regearing vs performance mods
Need some advise ! With 35 inch tires would it b better to regear first then install some performance mods or try some performance mods first an c f I get the results I want ?
Old Oct 29, 2011 | 01:33 PM
Zroe's Avatar
Regearing is always the best performance mod. I would save your pennies and do that first.
Old Oct 29, 2011 | 01:42 PM
jpkjk's Avatar
Thanks for the info an who makes the best gears out there or are they all about the same ?
Old Oct 29, 2011 | 02:04 PM
orfanidisnikolaos's Avatar
Regear first.... Worth every penny...
Old Oct 29, 2011 | 02:20 PM
jpkjk's Avatar
Any suggestions on size for best performance
Old Oct 29, 2011 | 02:37 PM
remark's Avatar
for 35s on an unlimited auto try 5.13
for 35s on an unlimited stick try 4.88
Old Oct 29, 2011 | 02:41 PM
jksteve89's Avatar
I have 4.88's on my manual two door w/ 35's. Plenty of power. I can now pass vehicles on the highway in sixth gear. Once I put a pro-rock in the front of the jeep I will probably try 37's with the 4.88's.
Old Oct 29, 2011 | 02:53 PM
jeeeep's Avatar
need more info on your jeep - for Auto, if you do much freeway driving or tow and want to keep decent mpg, 4.88
If you trail mostly, 5.13
the chart for automatic IMO is not correct as the Jeep trans up to 2011 is not a true 4speed, it's a 3speed with OD. If you ever need to lock out OD calculate your RPMs for 3rd by dividing the RPM's in the chart by .69
I'm running 4.88's with 35's, 21mpg freeway, 16 town. climbs great can run 75-80 on long trips no problem
can still lock out OD for towing without hitting too high RPM. I'm going to try 37's (closer to stock ratios) to see how it performs.
I ilke to be able to make full use of the trans and also lock out OD as needed without hitting the high RPMs
Old Oct 29, 2011 | 03:19 PM
Zroe's Avatar
I run 5.13 on 35s with a manual and think its blissfull
Old Oct 29, 2011 | 03:43 PM
nthinuf's Avatar
Get a programmer/tuner to recal the 35's, and then gears.
