removal of front axel question.
Old Mar 10, 2011 | 05:41 PM
SLVR07's Avatar
Default removal of front axel question.
I have an 07 with a Dana 30 in the front. Are there C clips holding the shafts in?
Old Mar 10, 2011 | 05:44 PM
Brashanic's Avatar
no. just pull rotor ,caliper, unit bearing and the axle slides out
Old Mar 10, 2011 | 06:24 PM
SLVR07's Avatar
Thank you for the responses
Old Mar 10, 2011 | 09:44 PM
Jeter's Avatar
you do not have to pull the abs wire when pulling the shafts. just lay your unit bearing up on the frame. Not a big deal pulling the wire though.
Old Mar 10, 2011 | 09:46 PM
u-joint's Avatar
I've done it both ways. Whichever way you find easier, it probably doesn't amount to much a difference either way
Old Mar 11, 2011 | 04:36 AM
SLVR07's Avatar
Good to know Thanks!
