Removal of Rear Speaker Bar?
Hello All,
I am installing some Thule Rack "feet" on my JK this evening. I have already mounted the rear ones, and all went well. Tonight I will install the forward mounts, just aft of the removable top pieces. Any available instructions if it is more complicated than that?
In order to do this, it appears that I will need to remove the speaker bar. Is there anything I need to know other than simply unbolting it? I'll try just removing the speakers first, as that might give me sufficient access.
Thanks.
DG
Thanks.
DG
Hello All,
Thanks.
DG
Thanks.
DG
Also, on the passenger side is the connector for the speakers and dome light. There is some slack but not a lot. You will be able to lower the soundbar to access the connector. If you try to grab it and run with it, you will rip the connector out.
