Removing Carpet?
Old Jul 23, 2007 | 04:49 PM
FunN4Lo's Avatar
Default Removing Carpet?
So I know the dealers and manual tell you not to because of the heat from the exhaust and engine, but has anyone done this? Any side effects? Also, I know there are wires running to the back right underneath the carpet above the wheel wells. Anyone found a clever way of hiding these so they aren't out in the open with the carpet removed? Thanks for any feedback.
Old Jul 23, 2007 | 05:56 PM
BigJerm's Avatar
only carpet ive pulled is the front carpet and right under driver seat. It does get a little warm on the feet and yes right above the tranny gets decently hot but not going to burn your skin. I got the Husky floor matts and they work great
Old Jul 23, 2007 | 06:21 PM
muddpuppy01's Avatar
the wire are already tucked up when you remove the carpet I remove mine the second dat I had the jeep and lever looked back
Old Jul 23, 2007 | 09:22 PM
really_good_guy's Avatar
Default RE
pulled all carpet and rhino lined. check out my photos in the project jk photo album. it does get a little warm on long road trips but nothing bad...def. worth doing if you are tired of cleaning dirt and sand out of your carpet after wheeling.
Old Jul 23, 2007 | 10:57 PM
2K1TJ's Avatar
Here's the link to your thread, for those interested.
https://www.jk-forum.com/forums/jk-show-tell-33/pics-my-jeep-including-rhino-liner-9487/
Old Jul 24, 2007 | 08:56 AM
FunN4Lo's Avatar
So...I pulled out all my carpet yesterday after some of your posts. Super Easy. I also just got the Husky Floor Liners. They work great. Good Fit and seem pretty durable. Also, I can now sell my vaccum and get a better hose. HaHa.
Old Jul 24, 2007 | 10:18 AM
BigJerm's Avatar
you pull the rear carpet too? I thought about it but i want to keep my rear tub cover in place and having the trapazoid piece of carpet in the middle of metal would look goofy i think
Old Jul 24, 2007 | 10:59 AM
FunN4Lo's Avatar
Yes I pulled ALL of my carpet out even the rear. I offroad quite a bit and I normally have the top down and all the carpet would get filthy. Frankly I got sick of vacuuming my entire car. Now I use an air hose. So far I have no regrets.
Old Jul 24, 2007 | 10:33 PM
FunN4Lo's Avatar
I'll try to get some up here shortly. Would you like pics with or without the husky liners in? Or both?
Old Aug 1, 2007 | 01:55 PM
saltman's Avatar
For those that have pulled the carpet. What did you do about the carpet cover for the little recessed trunk area? Did you just remove the door? Was the entire tub painted like a TJ? I've peaked under the carpet and mine looks spotty. I'm not so much concerned about the appearance as much as rust due to the water that's going to be getting on it.
