Removing front axels with c clips
Old Dec 18, 2013 | 08:03 PM
joentuff's Avatar
Default Removing front axels with c clips
Ok I bought a jeep and I believe there are c clips on the front axels, any help on removing these so I can pull the axels out to replace the ball joints? Can't find a write up on it
Old Dec 18, 2013 | 08:09 PM
all4wheels's Avatar
Project-JK.com - Jeep JK Wrangler Resource » Jeep JK Wrangler Front Axle Shaft Removal & Replacement
I don't know if this will help but check out this link.
Maertz's Avatar
No c clips just take wheel rotor and all that off remove the 3 bolts on the hub assembly and the shafts slide right out takes like 15 mins a side.
Old Dec 18, 2013 | 08:17 PM
joentuff's Avatar
It has the G2 axels with C clips, and lockers
Old Dec 18, 2013 | 09:41 PM
all4wheels's Avatar
I've never heard of a D44 C-clip axle, but if it has c-clips, then you have to remove the cross pin from the differential carrier, and PUSH the axle in. One side at a time, then fish the C-clip out with pliers. There will be one on the end of each axle shaft. The C-clip slips into a groove at the end of the axle shaft and then you pull the axle shaft out. This locks the C-clip in place in the inner diameter of the side gear in the diff. Once you install the cross pin, the axle shaft cannot come back inward and release the C-clip.
Old Dec 19, 2013 | 04:08 AM
joentuff's Avatar
its not a 44, its a dana 30
Old Dec 19, 2013 | 05:17 AM
kaptkrappy's Avatar
Originally Posted by all4wheels
I've never heard of a D44 C-clip axle.
Me either.
Are you referring to the C clips that hold the U joints in place maybe ???
"G2 now offers an even stronger option for the Jeep JK. The new Placer Gold axles feature the larger yoke that accepts the 1350 style u-joint found in Rubicon models. Forged from 4340 Chromoly, these axles are heat treated to handle the additional loads without failure. Front axle kits come fully assembled with Dana Spicer U-joints, and full circle clips."
Old Dec 19, 2013 | 05:42 AM
karls's Avatar
He says it isn't a 44, it's a 30. That could be why we've not heard of the 44 with C clips.
Sent from my DROID4 using Tapatalk
