Removing front dana 44 pinion nut
Old Nov 15, 2011 | 02:42 PM
alec05rubi's Avatar
Default Removing front dana 44 pinion nut
So the rear came off and went on using my 1/2 breaker bar. The front though...that's completely different! I'm installing TW shafts and need to change over the front pinion flange.
I can not get that thing to budge at all! Any ideas?
I did a search and only found one topic that started into a bearing pre-load discussion. I was able to remove the front tcase output with ease but no joy on the pinion nut.
It looks like the jeep will be rolling around as 2 wheel drive for a few days until i can figure it out!
Old Nov 15, 2011 | 02:45 PM
Cdyspeed's Avatar
You need a good compressor with a line to the tank not through the regulator and make sure it can go up to 150psi or so that's how I got it off
Old Nov 15, 2011 | 03:11 PM
l00py1211's Avatar
Yup, breaker bar is a bad idea. Gotta run an impact gun on it and it should pop right off. IF you don't have access to one, put on the rear d-shaft and drive to your nearest auto or tire shop and toss the mechanic 20 bucks to break it loose and hand tighten it back on.
Old Nov 15, 2011 | 04:43 PM
alec05rubi's Avatar
I'll go pickup an electric one from Sears or somewhere. My air impact was unable to break it loose. I looked up a few online and the electric ones say they are capable of 350 lb/ft to 1200 lb/ft in both directions.
Old Nov 15, 2011 | 07:42 PM
therza's Avatar
Originally Posted by wsutwiggy
I had the same issue.... I just used a little heat from a soddering tourch and mine spun right off
And don't reuse the nut. They are one use only. Go to the dealer and pick up new ones - T-case and axle.
Old Nov 15, 2011 | 07:51 PM
alec05rubi's Avatar
TW's sends two new nuts with the shaft It includes the tcase and the pinion.
Old Nov 16, 2011 | 08:31 AM
RubiBurst's Avatar
I bought a IR231 impact at the recommendation of another member and it backed it out in 5 seconds @ 90psi. My Craftsman didn't even think about breaking it loose set @ 150psi. As usual, it's all about the tools. BTW, the IR ran right around $100. Hope this helps.
Old Nov 16, 2011 | 08:40 AM
nelsonrullan's Avatar
Had the same problem, took the driver wheel off and use the h lift tube as lever Thats how manage to break it loose
Old Nov 16, 2011 | 05:00 PM
alec05rubi's Avatar
I was able to get it loose today using my floor jack. It took me a few tries but it came off! Tightened it back to 160 ft/lbs per the directions that came with TW's driveshaft.
Thanks for the tips!
Old Nov 16, 2011 | 05:35 PM
JKZinger's Avatar
If you are talking about the front driveshaft transfer case pinion nut, an electric impact didn't fit on mine. I ended up spraying some PB Blaster on it and then it came off with a breaker bar.
