Removing the O2 Sensor from stock intake
Old Mar 6, 2008 | 01:02 AM
brestman's Avatar
Default Removing the O2 Sensor from stock intake
am in the process of installing my Airaid CAI..What is a good way of removing the O2 sensor without destroying the original air tube just in case I want to put it back in the future.
Old Mar 6, 2008 | 04:30 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Unplug the connector,
Remove the stock intake from the Jeep, take it inside.
Patience. That is your friend here.
Make sure the tube is warm, so the rubber is as flexible as possible, I then used just a little wd-40 to slicken it up, and SLOWLY worked a small (maybe around 3/32 dia or so) rounded end metal rod in next to it, to use to spin around it to pull the rubber out of the small ring it grips into. I went slowly, it took me probably 15-20 minutes of fiddling to get it out of there, but it did come out undamaged.
Old Mar 6, 2008 | 05:22 AM
bswaltm's Avatar
Default cut it
razor knife, small inscision, it's fun you can pretend your a surgon.
Old Mar 6, 2008 | 05:28 AM
[N]UGE's Avatar
x2 on that one
very easy when you just cut the damn thing
Old Mar 6, 2008 | 05:46 AM
RedneckJeep's Avatar
It wasn't a dumb post at all. It was correct. It's an air temp sensor.
Old Mar 6, 2008 | 06:22 AM
Eternal ***erator
Originally Posted by [N]UGE
x2 on that one
True, but he said without destroying it. Cutting it of course is the easiest way, but I didnt want to cut mine either, as i may want to put it back, or sell it. So leaving it intact was my choice.
Old Mar 6, 2008 | 06:23 AM
Eternal ***erator
*L* i missed that completely
Old Mar 6, 2008 | 06:47 AM
whpony96's Avatar
Easy just warm the rubber up with a hair drier on high and is pops out easy..just twist as you are pulling it out..
Old Mar 6, 2008 | 06:50 AM
Just a side note....there is a product FAR superior to WD40 called PBlaster. It works so good, I can't tell you about it. It's not advertised as well as WD40, but it WORKS. The hair dryer idea is a great idea, too.
Old Mar 7, 2008 | 12:43 AM
brestman's Avatar
thanks for all the input guys...I do a lot of cutting at work..the nip and tuck kind of cutting!.....I like the idea of the hair dryer too!..I'll try it tomorrow...
