Removing shift knob on manual
Old Jan 9, 2011 | 02:16 PM
redjkofdeath's Avatar
Default Removing shift knob on manual
How do you remove the knob? And the knob on the 4lo selector?
Old Jan 9, 2011 | 02:19 PM
Full-Traction Suspension's Avatar
Former Member
just pull very hard..
Old Jan 9, 2011 | 02:26 PM
762's Avatar
762
just took mine off. use a screwdriver pry the top off and inside will be a clip that needs so be taken off, then the bottom will slide off
Josh
Old Jan 9, 2011 | 02:29 PM
wayoflife's Avatar
JK-Forum Founder
yup - maybe twist a bit at the same time
Old Jan 9, 2011 | 02:33 PM
Wallsofcrete's Avatar
Caution dont do what I did and pull really hard and with my face to close and hit my lip.
Old Jan 9, 2011 | 02:46 PM
blockrockin's Avatar
i agee alittle twisting while pulling seemed to do the trick
Old Jan 9, 2011 | 02:51 PM
Matt08jk's Avatar
You need a quick jerk with some power to it, the FSM says you might have to resort to a slide hammer-type puller and a rag to protect the knob.. Good luck!
Old Jan 9, 2011 | 02:52 PM
Good grief, how hard do I need to pull? I've tried pulling to an extent, but was afraid I was doing it wrong .... So, pull hard, don't whack self in face. Got it. How hard is it to put a new one on or even this one back on? If it's that hard to get off I can't imagine what it's like getting it, or a new one back on .....
Old Jan 9, 2011 | 02:57 PM
Rafi's Avatar
I pulled mine as hard as i could. got in some very awkward positions in the jeep to get at it. and it would not budge...
at all.
maybe in the 2010's like stated above there is a clip somewhere inside of it. maybe not... maybe mine is special. i had multiple friends also try. and it would not just "pull off"
twist pull or any sort of pull.
Old Jan 9, 2011 | 03:08 PM
backwoodjk's Avatar
I removed mine about two weeks ago. Twisting it was key to getting it off. It was a piece of cake once I used a Craftsman strap wrench.
