Removing Wheel Spacers
Old Jul 28, 2011 | 08:38 AM
awesomo's Avatar
Default Removing Wheel Spacers
Reading the SpiderTrax wheel spacer instructions, after installing it, I realized I might have installed the nuts backwards. According to the instructions, the rounded part of the nut should be facing the hub (inwards). I used the included red threadlocker.
I've driven on them for more then 1k miles with no problems...
-Should I bother trying to reinstalling and reversing the nuts?
-If so, according to SpiderTrax FAQ: "Even though red thread locker is considered permanent, grade 8 studs of 1/2” diameter and larger can be broke loose without damage to the nut or the stud. To reinstall make sure you clean the threads well.."
WHAT SHOULD I USE TO CLEAN IT WITH? BRAKE CLEANER?
-Is Heat really necessary to break loose these nuts? or can a breaker bar do the trick?
-Even If were to leave these as is, won't re-torquing cause the threadlocker to break loose?
Old Jul 29, 2011 | 06:22 AM
awesomo's Avatar
SpiderTrax recommended replacing these? If the nuts were really installed backwards?
Old Jul 29, 2011 | 06:32 AM
Bonedoc's Avatar
Definately remove them and reinstall properly. The rounded end of the nut is mad eto fit into a recess on the spacer that helps center it on the stud, just like the rounded end of a lug nut on a wheel.
Old Jul 29, 2011 | 01:33 PM
burbingus's Avatar
You definitely need to reinstall. The acorn nuts are designed to keep the wheel properly centered. You'd have 2 types of problems eventually if you keep the rounded parts up - wheels not centered to the axle, and the wheel rotating loosely about the center.
You can definitely remove the spacers and reinstall. I would spray brake cleaner on the wheel studs and let it soak for a while and then run one of your spare tire lugs up and down a few times on the stud to clean it off. Either that, or I would use a die to ensure the threads are clean. Afterwards, be sure to use red locktite again on the re-install.
Good luck!
Micah
