Removing "X" decal
Old Apr 2, 2008 | 08:42 AM
gongetya's Avatar
Default Removing "X" decal
Anyone have experience removing the x decal? How did ya do it?
Old Apr 2, 2008 | 08:46 AM
Jay Are's Avatar
try this thread:
https://www.jk-forum.com/forums/show...t=decal+remove
Rubicon Rando's Avatar
i am in the decal buisness and the easiest way for someone at home is to use a hairdryer and heat up the decal a little to release the adhesive then pull it off. shouldnt take to long. if there is any glue residue brakeclean or any solvent will take it off, just wash it with plenty of soap and water after and dont go scrub crazy on the paint. if you are afraid to use a solvent, plain old isypropyl alcohol works too, just takes a little more elbow grease is all
hope that helps
Old Apr 2, 2008 | 08:49 AM
myklt8's Avatar
Hair Dryer, soften it up, pull it off.
Old Apr 2, 2008 | 08:55 AM
derekls's Avatar
Just pull it off, i didnt even use a hair dryer and it wasnt hot outside, came off easy
I am putting a JK sticker where the X was
Old Apr 2, 2008 | 08:59 AM
gongetya's Avatar
Appreciate ALL of your help!
Old Apr 2, 2008 | 09:17 AM
RedneckJeep's Avatar
Originally Posted by toad
I just used my nail and pulled it off slowly. It does help if it's warm outside. The hairdryer thing should work good as well. I used goof-off to get off any lingering residue.
Goof Off is some STRONG stuff!! I hope you re waxed the area, cause I promise you it took any protective layer the factory might have put on. I used windex on mine and it worked great.
Old Apr 2, 2008 | 09:32 AM
greenmachine07's Avatar
hairdryer all the way !!
Old Apr 2, 2008 | 10:26 AM
RevyJKU08's Avatar
Hair dryer....any residue left I used VARSOL (Autobody Trick) and rinse are with soap and water.
