replaced lower control arm brackets
Old Mar 29, 2012 | 06:58 AM
ditchdigger's Avatar
Default replaced lower control arm brackets
So i had to replace my lower control arm brackets. I went with ******* Suspension Jeep JK Front Axle HD Lower Control Arm Mounts. in the instrucations you set your pinion to zero and then put the brackets on and zero them. guess my question is how may degrees from stock are my brackets now? or is that were my stock brackets where? thanks in advance
