replacement driveshaft on a lift kit?
I want to run a 3'' fabtech lift and i read on another site that it requires a replacement driveshaft. It said this on only one site and the rest dont say anything about it. Is this really necessary? Thanks. Please don't just post a link to another thread answering a ton of questions. Those thoroughly confused me because Im new to the jeep world.
If you have any lift and allow the front end to drop, as in going over a steep hill or a rock or even a parking garage ramp, the rubber boot that holds the grease in the joint on the transfer case side of the drive shaft can get damaged.
Once the boot becomes leaky, the grease will begin to spill out and you will eventually hear metal on metal squeaking with speed.
The more lift you have and the harder you drive it, the sooner this will happen.
So, do you need the new drive shaft with 3" lift, no you don’t.
Will you need it eventually, yes.
Q: Are new driveshafts needed after installing a lift?
A: You really should consider installing a new rear double cardin U-joint style drive shaft if you have lifted your Jeep JK Wrangler 3" or more and have a 2-door. This is needed because the short rear drive shaft of the 2-doors will be at a steep enough angle that the CV boots will wear out prematurely. However, in order to do this, you will need to buy a set of rear adjustable upper control arms so that you can properly set your pinion angle. 4-Door Unlimited models do not have this problem as their rear drive shafts are very long and a lift will not effect the angle of it too much. As far as the front goes, if you have an automatic transmission, you will need to replace the drive shaft with a double cardin U-joint style unit as well as the diameter of aftermarket shafts will be considerably narrower and will not come into contact with the transmission and/or skid plate. Failure to do this will result in the tearing of the factory drive shaft boot as it makes contact with the transmission. Manual transmissions will not have this problem and keeping the factory front drive shaft will not be a problem.
right out of the FAQ - nicely done Trending Topics
I really think they made that up for me and Redneckjeep cause they felt sorry for us having no life and spending half of our no life on hear. At least we can help or direct people to people who can help them. Hell, your pm box is gonna be full in a couple hours.
