replacement shift rod
Old Nov 19, 2012 | 08:55 PM
nevillebartos's Avatar
Default replacement shift rod
I have somehow scratched the rod for the manual trans in my 2012 a bit while whacking off the knob, cars only done a couple thousand Ks so wondering how difficult / costly it is to find this part and replace. If it's not too expensive ill switch in a new one, otherwise what would be best to touch up this with?
Old Nov 19, 2012 | 09:02 PM
Theonekyle's Avatar
You will have to get a doner rod from another JK, pull your center console out, there is a bolt that holds the rod in. See if yours is the same and make the switcheroo.
