replacement springs?
Old May 2, 2007 | 07:30 AM
oskee6's Avatar
Default replacement springs?
Anyone know where i can get a set of replacement springs that will offset the added weight (about 150 lbs) of a bumper/winch combination? I wasn't planning on doing this based on WOL's experience with the LOD front, but if its necessary, I'd like to be able to get the front end put together quickly. I don't plan on running a lift until i replace the stock tires, so all i would really need is a pair of springs that will level out the front.
The new setup will be an LOD w/brushguard and a warn 9.5xp. I've got the rubicon, so I'm guessing mopar won't have anything to help me there, and I've already installed the skyjacker spacers - which do a nice job of leveling a stock rig with the tow package, i would add.
thanks!
Old May 2, 2007 | 08:44 AM
Jeep School's Avatar
Just to clarify, you have the coil spacer lift already? On both the front and the back?
My suggestion would be to add the offroad (insert brand name of your choice) bumper in the back with tire carrier and equipment rack--just to offset the extra weight on the front, of course!
