Replacing the driveline?
Old Oct 22, 2007 | 06:36 PM
xoxoJeepGalxoxo's Avatar
Default Replacing the driveline?
So I have been looking around at different places, for lifts and tires and all that.. I went to a shop yesterday and they said it was highly recommened that get a new driveline with bigger tires and a lift on the 07 4 dr wrangler...
Does this sound right? Are other people having to do this?
Old Oct 22, 2007 | 06:39 PM
bly109's Avatar
It mostly depends on how big you wanna go.
Check out WOL's explaination in the FAQ sticky:
https://www.jk-forum.com/forums/show...76&postcount=4
Old Oct 22, 2007 | 08:55 PM
wayoflife's Avatar
JK-Forum Founder
As I've stated in the FAQ, it is not as necessary to do on a 4-door as the drive shafts are quite long. If you have an automatic, you may want to get a new front shaft as its smaller diameter will give you a bit more clearance between it and the auto skid. Other than that, the factory shafts seem to do quite well.
Old Oct 22, 2007 | 09:06 PM
wayoflife's Avatar
JK-Forum Founder
Originally Posted by TheDog218
what about on a 2dr. 07 X???????
Well, as I say in the FAQ...
A: You really should consider installing a new rear double cardin U-joint style drive shaft if you have lifted your Jeep JK Wrangler 3" or more and have a 2-door. This is needed because the short rear drive shaft of the 2-doors will be at a steep enough angle that the CV boots will wear out prematurely. However, in order to do this, you will need to buy a set of rear adjustable upper control arms so that you can properly set your pinion angle... As far as the front goes, if you have an automatic transmission, you should really consider replacing the drive shaft with a double cardin U-joint style unit as well as the diameter of aftermarket shafts tend to be considerably narrower and will not come into contact with the skid plate. An alternative to this would be to remove the automatic transmission skid plate or cut out a notch along the edge to prevent the drive shaft boot from making contact with it.
