Retorqing Wheel Spacers
After installation of wheel spacers it says to check and retorque them shortly after installation (after first 100 miles or so). My question is, if they are just a tiny bit loose and the nut moves a fraction of a turn, does that not break the seal on the locktite and render it useless? If it does move slightly when you check it, do you take it off and re-locktite it?
Thanks
BTW i'm talking about it just budging, not moving like a quarter turn or anything....
Thanks
I say re loctite the ones that were a little loose. I would think that those nuts act similar to the wheel lug nuts. I have had the RC and SPIDATRAX brand the RC's didn't say to use the loctite so I don't think it should be a big e
That's what I thought. I would just think that any torque you put on the bolt would effect the strength of the lock tight. Lol and i used locktight to make sure my exhaust doesn't rattle loose, i am damn sure gonna use it for wheel spacer!! Lol
Whenever I run wheel spacers I torque them to 95 ft/lbs. Then when it comes time to check / re-torque them, I set my wrench to ~92 ft/lbs. If the nut moves then I know I have to add new lock tite, if it doesn't budge then I know the spacers are good to go...
The lug nuts on the JK are supposed to be torqued at 95 ft-lbs according to the owners manual. When installing wheel spacers, torque them at 100 ft-lbs using the loctite, and check them at 95 ft-lbs after a few miles and at every tire rotation. If you don't find any loose lug nuts, you haven't broken the seal on the loctite and you should be fine. If you do find some loose, you have a problem. You will need to remove the wheel spacer and clean the lug nuts and the wheel studs and reinstall using new loctite an.
Joe
Joe
This is what I do...
