Reverse rake spring help AKA Prerunner
Old Apr 10, 2011 | 02:18 PM
Spdu4ia's Avatar
Default Reverse rake spring help AKA Prerunner
I currently have a 2008 X with Teraflex leveling kit. I am looking to add a stinger front bumper and want to get the front up about 2" more since it will probably sag about an inch with the new bumper and I like the look of the front raked above the rear (prerunner style). Can I just add a taller spring to my front ? What should I get and what all will I need? I'm still on the stock springs so anything will be an upgrade. Thanks
Old Apr 10, 2011 | 02:19 PM
nthinuf's Avatar
TF has a 'performance' leveling kit with coils. They say it gives about 2", and handles weight well. If you move to the TF2.5" coils, expect about 3" of lift.
Old Apr 10, 2011 | 02:41 PM
Spdu4ia's Avatar
will adding a stock Rubi front spring give me any lift up front? Is there any way to just upgrade the front springs an not anything else? Working on a tight budget.
Old Apr 10, 2011 | 02:50 PM
JulianK's Avatar
I did not measure exactly but my '11 Rubi with tow pkg sits as high up front as my '08 X did with a 1" coil spacer.
Old Apr 10, 2011 | 03:06 PM
20JK10's Avatar
Teraflex makes an actual PreRunner kit
http://www.teraflex.biz/jk-lcg-preru...uspension.html
Old Apr 10, 2011 | 03:09 PM
D_engel's Avatar
I believe rubi springs sit 2inches higher than a base x. You should be good with that
Old Apr 10, 2011 | 03:14 PM
Spdu4ia's Avatar
thanks! front Rubi springs shouldn't be too hard to find. HA thanks for the Teraflex link but little out of my pricerange.
Old Apr 10, 2011 | 03:23 PM
rexicon's Avatar
you want reverse rake
Old Apr 10, 2011 | 03:27 PM
Spdu4ia's Avatar
yep
Old Apr 10, 2011 | 05:52 PM
Harbourone's Avatar
The Cali lean baby!
Nothing like it to ruin an otherwise cool vehicle.
