Rides Rough -few questions please!!
Old Jul 27, 2009 | 03:40 PM
jonmorgan12's Avatar
I have a front and rear trackbar bracket is that the same as adjustable one? and i have gotten the front ended aligned like 5 times and I still feel like it is not fully aligned.. if you were in my position would you get front lower control arms or what?
Old Jul 27, 2009 | 04:03 PM
bostonMA's Avatar
The brackets add a fixed "extension" to the trac bar. An adjustable trac bar allows you to dial in the precise length to get the axle exactly centered under the frame.
More things to think about,
Where did you have it aligned, the tire place gave me a free alignment that actually made the thing worse. Thanks Town Fair!
And, do you think one of your wheels might be unbalanced. Does not fit you description perfectly, but is a possibility if you have vibrations and pulls.
As far as upper are lower, there are several threads on here. I went with the uppers before reading any of the debate and they have been fine for me.
Old Jul 27, 2009 | 04:06 PM
Well i have about $1,500 right now saved but i was going to invest in new 4.88 gears and upgrade to 35 inch tires. Do you think i should instead spend that money on lower front control arms and suspension components?
Old Jul 27, 2009 | 04:40 PM
BlackIce's Avatar
I drove home after liftin my jeep on stock tires (about 40 miles) and noticed some bump steer. After putting 35's on and tightening my trackbar(115 ft/lbs, top & bottom) the situation was resolved.
Hope that helps.
Old Jul 27, 2009 | 04:50 PM
TINMAN080's Avatar
sure sounds like you have a toe-out condition.....
Old Jul 27, 2009 | 04:55 PM
bigbluejk's Avatar
possibly a camel-toe condition.
Old Jul 27, 2009 | 05:52 PM
DeepSky's Avatar
You mean where the two tires are perfectly parallel to each other even to the naked eye?
Old Jul 27, 2009 | 06:32 PM
FlyingJeep's Avatar
Originally Posted by planman
Skyjacker Nitro shocks=stiff
Skyjacker Hydro shocks=nice and soft, and inexpensive
Your flightiness is due to to little caster and to little toe-in.
Here is a write-up that explains alignments:
http://project-jk.com/jeep-jk-write-...-end-alignment
If you don't want it to drive like crap, the minimum additional components you need to add are adjustable lower front control arms to correct your caster, an adjustable front trackbar to center your axle, and longer front and rear swaybar links. To be on the safe side, you also need either longer brakelines or brakeline relocation brackets.
Because you have a 2 door, eventually your rear driveshaft will fail because it cannot handle the steep angle required by a 3.5" lift. When it does, you will need an aftermarket rear driveshaft and adjustable rear upper control arms.
x2 ... That about sums it up.
Old Jul 27, 2009 | 06:34 PM
mkjeep's Avatar
But seriously, I would think he his toe set right and go from there, sounds like too much toe out on his rig.
Old Jul 27, 2009 | 06:35 PM
bigbluejk's Avatar
brilliant!
