Ried racing knuckles and synergy draglink
Old Feb 18, 2014 | 04:30 PM
roscoj's Avatar
Default Ried racing knuckles and synergy draglink
So I have ried racing knuckles and it has had a Teraflex draglink installed by a local shop about 2 years ago. So I decided to go with a synergy draglink instead. I get it torn down and notice the shop that installed the knuckles drilled the f-n already tapered hole to add a sleeve to install their draglink. Now when I go to put the synergy draglink there isn't enough threads to use the castle nut and pin.
So I'm trying to figure out how to make it safely work. Do I just go get a lock nut like the one that came on the Teraflex draglink or do I countersink the tapered sleeve into the knuckle to get the pin to thread into the castle nut?
Old Feb 18, 2014 | 04:59 PM
tiltz's Avatar
You have a couple options.
1. You can file down the channels on the lock nut so you can insert the cotter pin
2. You can get a 7/8 bit or a step bit and take a little material out of the hole so the tapered sleeve will wallow out a bit and allow the tie rod end to sit deeper.
3. You could see about getting a different tapered insert that has a wider opening. Ruff-stuff sells one. The one they sell is likely the same as the one you have, though....
I'd go with option two.
Old Feb 18, 2014 | 05:07 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Personally I would get a new knuckle. Or run the teraflex draglink.
Old Feb 18, 2014 | 05:44 PM
jeeperjkjeeper's Avatar
is the hole under the existing sleeve 7/8"? If so simply get the correct sleeve bushing from Synergy and you will be fine.
Old Feb 18, 2014 | 05:47 PM
DunnyBunny's Avatar
JK-Forum Ambassador
I think that the knuckle is a little thicker and adding he sleeve just makes it that much thicker and that's what sounds like the issue is. Is that it OP? Or is it not seating all the way down?
Old Feb 18, 2014 | 05:54 PM
roscoj's Avatar
The knuckle is thicker. Everything is seated and tight. The thickness of the ried knuckle and the sleeve is to much that the cotter pin for the castle nut won't go in. Teraflex has a different lock nut that worked. I'm starting to think I might indeed need to get a new knuckle. Just to much meat on it now. Any other suggestions?
Old Feb 18, 2014 | 05:56 PM
DunnyBunny's Avatar
JK-Forum Ambassador
The knuckle is thicker. Everything is seated and tight. The thickness of the ried knuckle and the sleeve is to much that the cotter pin for the castle nut won't go in. Teraflex has a different lock nut that worked. I'm starting to think I might indeed need to get a new knuckle. Just to much meat on of now. Any other suggestions?
Tried teraflex castle nut in the synergy?
Old Feb 18, 2014 | 05:57 PM
roscoj's Avatar
Would adding red lock tight be safe to run or would this be a disaster waiting to happen?
DunnyBunny's Avatar
JK-Forum Ambassador
Hey also can you flip the tie rod on the Reid knuckles or does it just raise it?
Old Feb 18, 2014 | 06:02 PM
roscoj's Avatar
No I did not. It's already been moved to another jeep.
