Rim size vs. tire cost
Old Oct 21, 2010 | 08:48 PM
StrokeHerAce's Avatar
Default Rim size vs. tire cost
Someone please explain to me why I can buy the same exact tire in a 15" tire for way less than the 17" and I am getting more rubber in the 15" tire. I feel that I need to lube up prior to putting tires on my Jeep for the daily driver stuff if I keep the factory 17" wheels. Nothing special, just something that gets good highway wear in the 33"-34" range. $237 each not M/B. I have found 15" tire and wheel combos that beat that...
Old Oct 21, 2010 | 09:00 PM
mkjeep's Avatar
By in large 15in rims have been thrown to the wayside because of the bigger brake systems on newr vehicles( my theory anyway) You can get 15in rims to work on a jk with either the proper backspacing and/or grinding abit off your brake calipers. Jk's brake systems are basically designed for 16in and up rims. 15in rims are cheaper because they are less wanted now. Tires are cheaper for the same reason. Supply and demand. You'll prolly have a hard time finding a good selection of tires that fit a 15in rim in 5-10 yrs. Off-road tires anyway. Hell, its kinda that way now.
Old Oct 21, 2010 | 09:19 PM
I like life way to much to start grinding on brake parts. Someone put that metal there for a reason!
Old Oct 21, 2010 | 09:23 PM
mkjeep's Avatar
Haha, they have a few members on here that didn't have to grind theirs , maybe they'll chime in.
Old Oct 21, 2010 | 09:46 PM
jtjk's Avatar
yea i also found this a bit strange, just bought new tires now and found that stock rims and spacers is almost the same as a new set of rims in a smaller size.
Old Oct 21, 2010 | 10:53 PM
bubba2u's Avatar
i have heard that the bead part of the tire is the most expensive part to make. that being said i went with 15" rims and i did grind a little off the front calipers to make them work.
Old Oct 22, 2010 | 03:09 AM
CJ7nvrstk's Avatar
Vet Army
No grinding on mine at all. Details in sig.
Old Oct 22, 2010 | 10:54 PM
mkjeep's Avatar
Originally Posted by planman
The supply of tires for 15s in 31, 33, and 35s should always be large due to the demand from all the non-JK wranglers, pre-WK cherokees, and toyota, ford, and nissan compact truck owners out there.
One reason tires for 15s are so much less expensive is that the are 6 ply load range C instead of 8 or 10 ply load range D and E tires.
The 15s are designed to be run at 35 psi at max load. The others are designed to be run at 55 to 80 psi at max load.
The extra material for the additional plus and the design to, for example, handle 4400 lbs each at 80 psi instead of maybe 2400 lbs at 35 psi makes for a more expensive tire to manufacture.
Another reason for the price differential is that the market for the 15s is so large that the design expenses are spread over a larger volume and the production expenses are also spread over a larger volume.
Oversized tires for 17" wheels are designed primarily for late model lifted full size trucks. So there is a smaller market with smaller volumes compared to the jeeps, compact trucks, older model full size trucks, etc. that have been modified sufficient to run oversized tires.
Sent from my DROIDX using Tapatalk
Well hell, that threw my theory out the window, notice I did say my theory.
Planman= KingofthePuck&WheelMaster
Old Oct 23, 2010 | 07:21 AM
Grant09's Avatar
This whole price difference is the reason when I started looking at aftermarket wheels, I was really looking for a 16" wheel. On a Jeep, I like the smaller wheel/bigger tire look, and on top of that, in some instances the same 33" tire was almost $50 cheaper for a 16" than a 17". So for the price of 5 tires, you're looking at about $250 less. That'll pay for one of two of the new wheels.
Old Oct 23, 2010 | 01:11 PM
nbro's Avatar
i gonna guess theres less demand for them??? i never really understood it either, i feel your pain though. im used to buying tires for 15" wheels and now i am looking to get a set of 15"s on my JK
