rim swaps
Old May 17, 2012 | 08:45 AM
scholes_76's Avatar
Default rim swaps
I had been running a set of 15" steelies for a long time because they were cheap, I was broke, and the stock steelie set up was horrible. I picked up a set of Rubicon take offs recently because I actually like the look of the stock aluminum rims. I have put a set of spidertrax spacers to push em out to where I like 'em and everthing is good. Except: I had intended to keep my 15" steel rims with their 33 12.50's as a dedicated offroad set because of the better cost of 15" tires, but now with the spacers they sit too wide. The help I would like is anyones experience with a 15" rim that has a similar backspacing as our stock rims so I do not have to remove my spacers everytime I plan on going back to my offroad set. Thanks for the help guys
Old May 17, 2012 | 09:17 AM
FlameRedJK's Avatar
Have no idea what the BS is on the stock wheels but, I run 35" MTRs on 15" Cragar Soft 8s, which I believe have 4"BS, with 1.25" All Pro Off Road spacers and they are perfect!
Old May 17, 2012 | 09:22 AM
09 jk renegade's Avatar
also keep this in mind, the higher you go (lift ect...) the wider you should go so unless they really stick out your probably better off.
Old May 17, 2012 | 09:27 AM
scholes_76's Avatar
I had though about that as well, is there a general rule for to wide? or is just a matter of finding that failure point in the components(balljoints etc)?
Old May 17, 2012 | 10:04 AM
holmes4x4's Avatar
IMO the wheels should always compliment your lift, never going to high or to wide without doing them together or like you said you can have failure on certain parts quicker and it can be unsafe. Also Im not a huge fan of spacers have seen a few horror stories about them failing. Also with this you need to put into account, flex of suspension, axles (upgraded or not), fenders (Flats(metal or plastic) or stock or none), engine performance, etc.. Not a perfect ratio but an idea of how it should go.
Stock - 2.5" lift =33s
2.5" - 3.5" lift = 35s
3.5"-5" lift = 37s
5" - up = 37s - up with obvious mods done
Old May 17, 2012 | 10:14 AM
FlameRedJK's Avatar
I know guys who run 40s with full hydro steering on top of spydertrax and they have had zero problems for years...A lot of people blame their problems on spacers but, I'm not convinced, as long as they are PROPERLY TORQUED, you shouldn't have issues IMO.
I agree on your examples of lift height to tire size.
