ring gear wear pattern
Old Mar 15, 2010 | 02:23 PM
rocknredrubi's Avatar
Default ring gear wear pattern
Is this an expected wear pattern? I am tracking down a noise coming from the rear. If another angle is required, let me know.
Old Mar 15, 2010 | 02:50 PM
kflash's Avatar
What's the noise you are hearing?
Old Mar 15, 2010 | 03:08 PM
I have another link to that. Basically a metalic noise that gets loader as I go faster. Do these gears look OK?
https://www.jk-forum.com/forums/modified-jk-tech-2/strange-noise-122138/
Old Mar 15, 2010 | 04:16 PM
nangulator's Avatar
https://www.jk-forum.com/forums/showthread.php?t=122138
Do you have any issues with the locker, like engaging or unlocking?
Old Mar 15, 2010 | 04:21 PM
Suffolk JK's Avatar
From the looks of it, the center is catching, which looks ok. How is the pre-load?
Old Mar 15, 2010 | 04:30 PM
jkman77's Avatar
With a lift installed your axel will twist the pinion up. Because of this your outer pinion bearing my be running dry. If you install a lift or adjust pinion angle you should over fill diff to make sure all internals get lube. Drain diff fluid. Check for metal chips. Then refill . But it may be to late. I run about 3 quarts in mine. 2 up front.
Old Mar 15, 2010 | 04:39 PM
BlackNorthernJK's Avatar
Well I'm gonna say it's virtually impossible to see how your gears are meshing by this photo, get some paint to spin a pattern...but I highly doubt that's your problem....usually your going to hear a whine, not a grind if your gears aren't meshing correctly...'cause if your hearing a grind between the gears, something would BAD WRONG...and because it aint a big pile of metal garbage in there I bet they're fine.....bearings? ...possibly...but how did you pinpoint the sound? ...put the rear end up on jack stands, run the engine and put it in gear to pinpoint your sound
Old Mar 15, 2010 | 04:43 PM
Brashanic's Avatar
if there isn't any metal you are probably good. you can't really tell from the pics but it doesn't look like anything wrong in your gears.
if it was me i would be looking other places
Old Mar 15, 2010 | 04:46 PM
mikesjk's Avatar
Wiredwag_mg had a similar problem and it ended up being twisted splines and a bent axle shaft rubbing the axle housing. Hopefully this helps you out.
Old Mar 15, 2010 | 05:10 PM
Good advice. I will do this tomorrow.
