RIPP Meth Controller setting???
I am going through this stuff like water. Approx 400 miles per tank. I have my "start" set to 2 and my "full" set to 5-6. I have checked all connections. I replaced a faulty nozzle, and still using, I feel, too much. Any suggestions??? I am going to hook up an LED tomorrow to the pump wiring to see, in the cabin, when it is working. Also, got my first lightning bolt this evening. Hope it is a fluke. Transmission seemed confused when leaving a stop light. Shifted up, down, up, etc. then light. Took it out later and drove it hard, no light.
Start: 4psi
Full at 15psi
Lets try to isolate it to a controller - again this is an odd issue - we usually have zero issues with the METH system.
If your running rich do to the meth over spraying it may add to the TRD issue. Plus a TRD in the first few hundred miles is common -
RIPPTECH
