RIPP SC CA SMOG test
Old Oct 11, 2012 | 09:02 AM
socaljeep's Avatar
Default RIPP SC CA SMOG test
Hey Everyone,
Has anyone had any issues with their JK with the RIPP Gen 2 + Air-to-Air intercooler passing the CA smog check/test.
Old Oct 11, 2012 | 09:47 AM
TURTLECON's Avatar
Originally Posted by socaljeep
Hey Everyone,
I thought you got rid of your JK bro?
Old Oct 12, 2012 | 08:26 AM
socaljeep's Avatar
Hey man,
I am in the middle of the sales process with a buyer now and his lender / credit union is requiring a smog certificate which is apparently required per the DMV... I think it should be fine, but was hoping someone on here might have done it and could provide some insight before I go do it...
Old Oct 12, 2012 | 09:29 AM
Flip94ta's Avatar
Did ripp supply you with a carb sticker or certification number? I'd google that info.
Old Oct 12, 2012 | 09:51 AM
wytmike's Avatar
It will not pass the visual. It should pass the sniffer unless you have other problems. RIPP is currently working on getting CARB approval but I still think it is a little ways out. Last time I heard they were looking for a test jeep in Southern California that CARB could run their tests on.
Mike
Old Oct 12, 2012 | 09:55 AM
wytmike's Avatar
If you still have the stock air cleaner assembly, you can pull the supercharger. Leave everything else, including the programing and you will pass. Put the supercharger back on after.
Mike
Old Oct 12, 2012 | 06:31 PM
RIPPMODS's Avatar
Sponsoring Manufacturer
Mike
We were able to secure a stock 2010 JKU and it has had a Gen 2 Stage 2 installed and has begun the battery of tests needed for CARB #. We do not know how long the process will take. The estimate is 4 weeks at this point. You can always call us to find out how far along we are.
RIPP
Old Oct 13, 2012 | 05:57 AM
socaljeep's Avatar
I don't believe so, but going to look into it.
Old Oct 13, 2012 | 05:59 AM
socaljeep's Avatar
Mike
Thanks for the info.
Old Oct 13, 2012 | 06:00 AM
socaljeep's Avatar
Mike
I called RIPP support to discuss and this is what they suggested as well. Thanks again,
