RIPP supercharger
The BOV vents directly to atmosphere. I am guessing you are looking at recirculating in order to cut down on noise? I am willing to bet RIPP would mod the intake tube to allow for the recirculate option. However, since the the BOV is sitting right above the air filter and intake pipe for the blower, I am not sure how much of a noise reduction would actually be achieved? I am interested to see what RIPP has to say.
I hope I don't tick anyone off but here goes anyway, tonight I was on the phone with MBRP. I asked Steve how he liked the Ripp SC on the two door they have. He told me that it has been a great setup yada yada .... but what surprised me is that he feels the SC two door would win in an acceleration race against the Hemi filled four door they have
I don't know what you guys do with your jeeps but I drive long distances to get to where I can wheel. It's the drive to the fun that is tedious
. The little 3.8 just doesn't cut it out on the open road but with my 4lo it climbs pretty good. I am looking to add 35" tires next and may finally get serious about the SC Ripp makes. I only have one reservation and that is NO performance shops in the area to install or tune. Hey Ripp how about a road show across central Missouri with parking lot installs?
. I don't know what you guys do with your jeeps but I drive long distances to get to where I can wheel. It's the drive to the fun that is tedious
We’ve also DYNO tuned 5.7l 1500 Series Dodge’s a found 225whp with exhaust and filter mods. They pick up about 20hp with tuning.
Just curioius but I live in Oklahoma and the elivation here is around 750 feet. I take my Jeep to Colorado evey year and drive up in the mountians. Will the standard tune used for 90% of my driving work well up at 12K feet? Will I need a different tune up high? I don't want to foul out the plugs up there. Seems the MAS would compensate for the thin air up there but was just curious.
Jeff
Jeff
So in working with reputable shops in Colorado, Wichita and Montana we came up with a solution that makes sense. Rather than using the switchable maps for High and Low octane, they are converting one of the two maps to High altitude and low altitude. Both the clients and tuners like the idea, and demonstrates the flexibility of the system.
A 6spd JK running 35’s and gears produced 190 rear wheel HP before tuning. With tuning they made 250 rear wheel (DYNO SHEET BELOW).
After consulting with these shops it became clear that aftermarket performance kit like ours almost always need to be fine tuned for elevation. By our calculations we thought the factory base mapping would swing the tune around enough to compensate - the dyno numbers prove that's theory wrong. If you are at altitude factor a quick tuning session in ($250-400) into the project. Please call our tech line for further advice.
do you have an auto?
if not how are your highway speed rpms that low with 4.88's. i have 4.10's and in 6th gear at 65, im right around 2200.
i have been in a ripp sc'ed jk and it is a night and day difference. it actually amazes me that people want to spend an extra 15k for a hemi. as i dont feel the money difference......if that make sense. i will say that it actually makes it fun to drive on the freeway.
when i get the funds together i will be doing this mod.
shaun h
shaun h
Our JK units will follow the same principle, Stainless steel - long tube race collector. Primary size will be determined by HP/Trq output.
Frankie, Ripp Mods, there seems like there is a little difference of opinion on this, my crusing RPM is around 2000. Is there or is there not a difference? If so what are the numbers?
The reason I'm asking about the numbers is that I hear that the catbacks, air intakes, and performance chips which I added had what is described as a "noticable" difference wasn't very noticable to me.
Yes –with the blower in place all the above it true – except there is a huge air pump ready to deliver if not boost just a whole bunch of air that your engine can take advantage of. You’ll still have to come out of torque converter lock up, and as soon as you do that the engine will rise to 2500-2700 in over drive and you’ll find 1-3psi there, or if the load (throttle input) is enough you'll, the ECU will ask for a down shift to 3rd gear and 4-5psi ready to be applied. You learn to use the blower as "displacement" per-say – Where you learn where the boost is and apply it as needed.
This is a very large blower – in fact on paper its quite over sized – we chose an oversized blower because its better suited for the lazy –narrow angle V6 – Yes, we take full advantage of the timing at low RPM –and no matter where your foot is, we tune on the outside of the tune –
frankie945 Your experience must be (albeit more conventional) with straight ECU tuning, larger injectors and fuel system. We are not that type of kit; we are deflective tuning and supplemental injector. This presents the added benefit of being able to take advantage of the blower’s willingness to deliver air – both boosted and in volume. Since we are monitoring the ECU via various sensory we have the ability to correct as much as 15% (-/+) according to the base line programming coming from the ECU. The variable being boost/vacuum. This allows the end user to drive the throttle differently. So if you’re at 2000 rpm and need some acceleration. Press the gas and we’ll be a great NA solution throwing timing forward and soaking up the JK's inherently rich tune and as it seamlessly transitions to boost just 200rpm later, we pull it back and feed fuel accordingly.
Once you add the blower – you can hear the blower load up and change sound to a loaded boosted state – Once boost is present you can apply it as needed 1-7psi and roll off the throttle like a larger displacement engine. It takes a little time to master, but it all makes sense when you feel it come together.
First of all, thanks for all the help, and forgive my ignorance, but a few more questions.
If I read this right, the graph doesn't even start until after 1800 RPM, so we don't know what happens below that. Then, I'm assuming both blue lines are the SC modified and the red lines are stock. I'm also assuming the bottom line for each is horsepower and the top is torque (since the MAX HP or 234.8 lines up with the highest peak on the bottom blue line). Comparing the two top lines, at about 2000 RPM, there is about a 25 FtLb torque increase, but not much of a HP gain at all (maybe 10 HP at most).
That doesn't sound like much to me. Frankie, What does WOT and TPS mean (again, excuse my ignorance
)?For some reason you sound , I could be wrong, against the
supercharger. Wether it be this specific type or just forced iduction in general, I don't know.
You claim the sc needs load to make boost, true, and in 6th gear at highway speeds there is load on the motor when the skinny pedal is pushed. Hence the reason downshifting is required. This motor doesn't make very good power down low in NA "mode", infact I'm rarely below 2400 Rpms anyway. So I don't really understand your rebutle.
I would say that 99% of my driving would benifit from this blower, I would even venture to say the same for the vast majority of the rest of the jk'ers out there. And since most of can't afford a hemi, so this is one of the few solutions for USEABLE power.
I know what the two stand for but my question or response
to you is why does it matter. When you dyno a motor it's done at wot not part throttle. Our jeeps at highway speed need more than just a light touch on the skinny pedal to accelerate especially when staying in top gear. This is where the load comes in that you speak of. I live in the dallad area and even on a few of the hills we have here I have to literally floor the jeep in 6th just stay at a constant speed. I won't even included if there is a heavy wind.
Secondly what does matter what the motor is doing at or just above idle, seeing that your jeep does nothing for power wise at those rpms. To me it's pointless because these things are meant to tow heavy loads to begin with so massive amounts of tq and hp aren't needed. Ripp IMHO have a product that makes the jeep much more enjoyable to drive. I bet that there is less than 5% of us that strictly use our jks for offroading, which tells me this product makes more power where the vast majority need it.
Sorry for any typos or spelling, I'm on my phone
That’s correct – most aren’t looking at the tach correctly – however this is a hefty investment and expectation should be set going in. Those interested should monitor their tach's while driving and see what the engine is doing to keep you moving. Then try to factor in the HP on the dyno graphs to see if it fits. You should find that at the RPM's you driving you will have a substantial amount of added HP, which makes living with a lifted JK much more appealing.
Our point is keeping the engine happy, you on the road and the extra HP to keep you truckin.
just a thought but maybe just save your money up and use it as a down payment for the 2011 Wrangler with a new powertrain and swap over everything from your current rig, thats my plan when the 2011 comes out i will be getting rid of my 2dr 2008 for a 2011 4 dr and swap everything over.
I never said anything about power down low..... Super chargers yield there power at the top of the of the rpm band. I have not even went WOT in my jk yet. And SC's are known for making more whp the wtq.
And yes all dyno pull are done WOT. I was just pointing out to the other person about load. I have been boosting cars for 15 years now. Back when guys were putting 100 dry shots of nitrous on there mustangs. I was spraying pure meth in my turbo grand national. And smoking there azz.
Does anyone on this forum have a dyno sheet of there own ripped JK. I would really like to see it.
I'm not flaming RIPP at all. Just getting the facts straight. And If it matters to you I would choose the RIPP SC over the HEMI just because of cost. But there is a few things I would change. I'm not going to get into that. Another time.
their are a few dyno runs on you tube. i have one from mine.. ill have to look for it
[URL]
checked vid. That was done at ripp right? I want to a dyno sheet from another shop. To see the difference. A dynojet would be great..
BTW nice JK love the redrocks.
Does anyone know if the ripp SC comes with a recirclelating bypass valve option?
[URL]
This was completed last month by Bullhide 4X4 in Colorado (one of or dealers), so this HP was found at altitude on a 6spd running 35” and 5.13’s through a stock exhaust. Also note that the torque is 266lbs/ft and not 416. The 416 is interference.
This is a fresh install not tuned on a automatic JK running 35’ and 3.73 gearing with proper gearing this will make 230 rear wheel HP (whp)
here are a few dyno runs from you tube.
http://www.youtube.com/watch?v=-cUsq2tKLso
i have one from mine somewhere
Our BOV is open to atmosphere – we point it directly at the fire wall to help clear the area of dust when you’re off road and move air under the hood. If you turn the BOV around and point it towards the fender its much quieter. It also blows a lot of under hood heat right out the side of the hood.
Recirc can be done – we never visited the topic.
I think something that would make me pull the trigger on the Ripp kit ASAP would be if it was possible to get significant boost (2 - 3 PSI) at 1800 RPM on up. Speaking as someone who knows engines, I am wondering what the feasibility would be for Ripp to have a bypass or blow-off valve at a preset pressure. This way you could get significant boost with the centrifugal SC at lower RPM (whether from a smaller pulley or larger blower unit) but also limit the boost in the upper portion of RPM (so the engine doesn't blow). I know it wouldn't be the "most efficient" thing as you would be pressurizing more air and then just venting a portion of it off, but this is my reasoning.
I spend 99% of my time at or below 3000 RPM. This means if the boost could be something like 1 - 2 PSI at 1500 RPM, 2 - 3 at 1800, 3 - 5 PSI in the 2000 RPM range, 6 - 9 in the 3000 RPM range and then with the 9 PSI blow-off just 9 PSI maximum (even if the SC is capable in that set-up to do 12 - 15 at red-line. This way we get a nice boost in torque at lower RPM than the current set-up but don't risk blowing the engine if it accidentally gets revved really high. Also being that I almost never hit 4 - 5K in its current state, I don't care if the system is horribly inefficient in that engine speed range
By the way cheers to Ripp for putting up with criticism and still answering questions the best they can
We would rather a few less ponys and drive our rigs a long time - than have a more powerful broken one.
We specifically chose a centrifugal for that reason - Jeepers use there jeeps, and the ones that know how have less parts and go further. We couldn't in good faith worry about bottom end knock, when we know JK's go deep into the mountains and dessert for fun...
If your going to press down on the block like that you should build it and run a more powerful electronics system.
Lastly - the V3 Blower we chose can be spun much faster than its current configuration, however without the supporting mods we can't. Namely headers and cat set up that can take the heat. Thats why we are moving in that direction. Our plan was to put a substantial amount of kits out there to prove the reliability and approach - now we can start playing with more power.
RIPPTECH
I know many like the idea of the roots style Avenger SC, but has anyone actually driven a JK with one? I think the Avenger kit looks great, and could be promising, but who's seen one in person or driven one? Nobody on ANY jk site has an Avenger SC and while some people "think" it may be superior that's only based on the fact that it's got a roots style sc, where's the proof? That's really not meant to be a rhetorical question either. Seriously, where's some data both from Avenger and from some people with the kit.
Root style blowers belong on V8's IMO. And yes $5k for just 100 or so rwhp is kinda high. The blower it self is $2,300 new. But you have to pay the price if you want to go FI.
I guess speaking as an engine designer I don't understand many of the problems you stated. If you simply increased the dose of methanol from your current system or started injection at lower RPM (a simple electronic tuning tweak), that is a way of raising the octane and easily dealing with any knock you may get from the increased residence time of the boosted air/fuel charge in the cylinder at slightly lower engine speeds. Since I have heard most people need to use fairly pure methanol (not the prestone de-icer) I would just assume get a bigger tank for the fuel methanol and leave the washer fluid reservoir alone anyway...
Additionally you say you worry about the heat generated from such a system as I described. Basic principles of engine building/designing say that the delta Q (heat flow) through the exhaust system goes up as a function of engine speed, load, and boost pressure. Based on many previous posts, the current system that you guys have out has been said to generate approximately 9 PSI at 5K reliably (what I based my theoretical max pressure on). Based on that there is less heat flow through the exhaust at 9 PSI at 4K RPM (which I very rarely venture to anyway) and much less heat at 1 - 3 PSI at 1200 - 2000 RPM. I would personally be happy with a maximum boost pressure of 6 PSI from 3K on up so long as boost started around 1200 to 1500 RPMs where I would use it on a daily basis...
I apologize if I sound frustrated with the current offering, but I just can't see spending $5,000 for something that I wouldn't use nearly enough to justify the expense and is only useful at high engine speeds (3K + RPM) where engines have much more of a tendency to blow than engines running at low RPM with a few extra properly tuned PSI. Perhaps I am looking at this from the perspective of being too practical like wanting a daily driver with a few more ponies during normal driving rather than something that drives normally but that you can take to the sand dunes or track on the weekends to open it up
If your next wave of kits can offer boost beginning much earlier in the engine speed range I will be the first one on-board as I love the design and simplicity
But until then I will continue to save money and plan a resonably priced solution to the lack of low-end power I have (a.k.a. I can't afford a hemi
As for the Avenger (twin-screw/roots blower) they are currently completely moving their testing and manufacturing site. That's the main reason nobody has the JK kit yet from them yet. I have been talking back and forth with them as well to try to use my knowledge to help enhance all the offerings available to all us JKers. Unfortunately it seems that for the perfect solution for all of us craving a bit more power from our rides will need to wait it out for at least a few more months...
Conversely, centrifugal superchargers like the self contained V3 Si-Trim Vortech we use, build boost in direct relation to the natural air flow of the engine. This simply makes the engine feel larger in displacement throughout the entire RPM band and by default more efficient. Pair that to the way we fitted it completely on the outside of the factory system and there is little to no risk of you getting stuck in the middle of nowhere. So our message remains – our kit –as a whole - makes sense for the way a Jeeper uses there Jeep. Additionally your not limited in the future should you decide to build your engine up to run more boost.
With respect to methanol – we are not advocates of straight methanol/alcohol injection in this application… Pure Meth can and will corrode aluminum, if your looking for engine longevity (which most Jeepers are), this should directly impact their decision. Sprayed at the diluted levels we are using it, it evaporates before the chemical touches any metal – this delivers both air density and added octane with little risk. But it’s not a 100% necessity and if it’s not present it will only cost you a few HP and not risk knock. When we were in testing stages running in a continuous state for 10mins on our eddy current loaded dyno – we measured air temps at the intake as high as 180-200 degree’s. The meth brought it down a peak of 100 degrees and a minimum of 50. It did suppress knock and provide cooling at any speed and RPM giving us the ability to run in ignition advance and thus more efficiently. A point we want to make abundantly clear is a roots is known around our industry as the hottest type of supercharging available. Air temps can idle higher than our operating temps. Yes, you can run a sandwiched intercooler in-between the blower and the cylinder head, but you’re still relying on the heat dissipation of the front mounted heat exchanger, a pump that can fail and hose throughout that can be cut of ripped off. This leads to running your tune a bit on the rich side to bring cylinder and Exhaust Gas Temps (EGT) down, prompting waste. If you’re wheeling at 5-10mph and are looking for efficiency in all aspects, you’re not going to find it in a roots or its supporting components.
Your welcome to feel frustrated – and even upset – for the investment you have the right to feel anyway you want. You don’t need us to tell you that you should only invest in what you’re convinced is the right thing for you. But don’t under estimate our system – its not an over inflated bunch of components in a box. We use high quality components throughout. For example we use stainless steel idlers and hardware, powder and black oxide coat all bare metal, SKF precision bearing in all rotating assemblies, and check for shaft concentricity down to the .001. Combine that with a turn key system and a network of skilled ready, willing and able dealers around the world, a customer service department that never leaves you feeling alone in your investment, and the few supporting mods we have coming out for 2010 to make more power– and that’s what your spending money on at RIPP!
Your argument is legitimate – but it's one from one perspective – a roots will deliver from 1800-2500 – We feel we deliver the whole package.
Thanks for the perspective,
RIPPTECH
Thanks to Rippmodds for all your replies and clarifications.
I have been following all supercharger threads with great interest. So far, the info I am gleening from these threads is supporting my plan to pull the trigger on the Ripp SC next spring.
i agree, major prop to ripp. these guys are always on here to answer our questions and they are always polite and respectful. good job guys.
like i said before, when i get the money tis will be the route im going. i am really anxious to here about your long tubes. will you do test on a stock jeep so we can see what we are getting before the supercharger.
shaun h
shaun h
