rk 2.5 stock mod
Old Feb 27, 2014 | 03:24 PM
shawnphi1's Avatar
Default rk 2.5 stock mod
Just rec'd my lift kit and planning on installing it this weekend but I have one question with the sway bar links that came with kit. Are they for the front or rear? Not real clear on the instructions. And I thought I read somewhere that the stock rears are longer so they can be moved/used for fronts and new sway bar links on rear. Then I read where guys are boring the holes in front swaybar to accept new links? I have a 08 2dr rubicon auto.
Old Feb 27, 2014 | 04:04 PM
whitejeepjk's Avatar
From what I have seen, the new ones are for rear, old rear ones are then moved to front
Old Feb 27, 2014 | 10:17 PM
AlexjeepVb's Avatar
The new ones are for the front, and offer to make the a quick disco if you don't have a Rubi. With the RK 2.5 you will reuse your factory rears unless you want to get longer ones, but really not necessary because the rear sway bar is so small.
Old Feb 28, 2014 | 02:26 AM
OH9JK's Avatar
JK-Forum Ambassador
Alex is correct. The links that come with the RK kit are for the front swaybar.
Page 15 of the PDF goes into detail...
https://drive.google.com/file/d/0B7I...it?usp=sharing
Old Feb 28, 2014 | 01:48 PM
shawnphi1's Avatar
Thanks for your help on this! Looking forward to installing the lift tomorrow.
Old Feb 28, 2014 | 03:38 PM
Billbikes's Avatar
Take the rear sway bar off and hang it on the wall. It'll do you as much good there, lol.
Old Feb 28, 2014 | 03:40 PM
Billbikes's Avatar
My X Factor came with both fronts and rears. I'm not going to use either, I think.
Not running a rear sway bar any more, and have JKS on the front.
