RK control arm question
Old Nov 4, 2014 | 03:03 PM
BlkSlvrJK's Avatar
Default RK control arm question
So I just picked up some RK lower front arms, I have a Rubicon Express 3.5 lift with the camber bolts. Wanted to know if I can just mount arms even though I had to punch out those little things for camber bolts to turn? Or do I have to close up slots again?
Old Nov 4, 2014 | 03:24 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Close the slots.
Old Nov 4, 2014 | 03:49 PM
BlkSlvrJK's Avatar
Thanks
Old Nov 4, 2014 | 04:38 PM
nthinuf's Avatar
Synergy makes a 'cam bolt eliminator kit'. Looks like just a couple thick washers, but might be worth checking out.
Old Nov 4, 2014 | 04:53 PM
mattgt5's Avatar
Teraflex makes a washer kit to that recenters the bolt in the square cut out.
sent from my work leash
Old Nov 4, 2014 | 04:57 PM
BlkSlvrJK's Avatar
That is good to hear!! Thanks!
Old Nov 4, 2014 | 05:10 PM
BlkSlvrJK's Avatar
Maybe I will tack those washers in place , don't plan on going back to cam bolts
Old Nov 5, 2014 | 01:36 AM
jeepfan30's Avatar
I used the Teraflex cam bolt eliminator kit when I replaced my cam bolts with RK arms. I had them tack welded in and good to go.
