RK double adjustable front track bar install help
Can anyone lend any advice, or a step by step here? The instructions that came with the track bar are pretty vague to say the least (they cover installing 2 or 3 versions of their lifts, and make no mention of how to install the TB). I've never done one of these before, and the double adjustability and overall install process has me
. My axle shifted approximately .5" to the driver side. Thanks in advance for the help!
. My axle shifted approximately .5" to the driver side. Thanks in advance for the help!Thats what I did for my 3.5" lift but can't remember the length
Sent from my LG-LS980 using JK-Forum
Two bolts hold it on, just remove the old one and replace it with the new one, pretty simple. If your axle is .5" off center make the new track bar 5/8" longer. The double adjuster allows you to loosen both jam nuts and spin the rod while it is on the jeep to adjsut the length. I would put some blue loctite on the jam nuts so they don't loosen up once you get it adjusted to length.
So I found the length based on lift specs (thank you!), but it seems that all of their instructions install the track bar with their bracket. Is that something just specific to the RK kit that helps re-locate the steering stabilizer (as the instructions seem to indicate)? Just want to make sure that I don't take it all apart just to find out it won't work w/out their bracket.
