RK Leveling Kit--Help
Old Jan 7, 2012 | 06:58 AM
86 CJ7's Avatar
Default RK Leveling Kit--Help
I just installed a RK leveling kit, but am having problems with the new swaybar disconnects. The disconnects use 1/2" bolts and it requires that you enlarge the holes at the end of the swaybars. Now after drilling for over an hour and burning up 3 drill bits, I have given up and put the stock swaybar links back on. What is the easiest way to enlarge these holes?
Old Jan 7, 2012 | 07:01 AM
wayoflife's Avatar
JK-Forum Founder
using the right kind of drill bit helps out a lot. in the past, i've used a unibit that goes up to 1/2" and that's worked out the best. using a cobalt metal drilling bit should do the trick as well. it also helps to use a drill that you can control the speed on.
Indy08jk's Avatar
Try using a step bit. Go slow and keep the bit cool with cutting oil.
Old Jan 7, 2012 | 07:43 AM
OH9JK's Avatar
JK-Forum Ambassador
Are you using cutting oil? Also make sure you are using a high quality drill bit. Go slow and steady....don't forget the cutting oil!
Old Jan 7, 2012 | 10:56 AM
CerOf's Avatar
Can't say enough times to use a SLOW drill speed. If not, you will dull out the bit in less than a minute.
Old Jan 9, 2012 | 03:42 AM
86 CJ7's Avatar
Thanks for all the advise. I have a unibit in my toolbox. I get some oil today and give it another go at it his afternoon.
