is RK track bar left hand threaded?
Old Apr 26, 2014 | 03:36 PM
JayswranglerX's Avatar
Is the jam nut left hand thread?
Maybe that's why I can't get it off going the normal lefty loosey. ..
So does it turn clockwise to loosen?
Sent from my LG-LS980 using JK-Forum
Old Apr 26, 2014 | 04:34 PM
Anyone know?
Old Apr 26, 2014 | 04:48 PM
Rebar-7's Avatar
Originally Posted by JayswranglerX
Anyone know?
.......yes
Old Apr 26, 2014 | 05:01 PM
Originally Posted by Rebar-7
.......yes
So the jam nut loosens by turning it clockwise if your looking at it standing on the driver's side of the jeep?
Old Apr 27, 2014 | 08:15 AM
Smashboogie 4x4's Avatar
Former Vendor
These are not left hand thread. Jam nuts are just very tight. Its possible that the original installer used Loc-Tite to prevent the nuts from coming loose. It is also possible that they are rusting or corroding in place. Spray everything with some penetrating oil and give it a shot. If that doesn't work you may need to remove the track bar so you can lock it in a vise and get a better bite on it. If Loc-Tite is involved you may need heat to get it to loosen up.
Old Apr 27, 2014 | 01:22 PM
Yeah we tried everything to get it loose including taking it off and clamping in a vice and using a bid ass crescent wrench and it wouldn't budge.
So corroded I think its toast.
May just need to replace it.
Old Apr 28, 2014 | 02:27 AM
OH9JK's Avatar
JK-Forum Ambassador
Do you have a way of putting heat on it? A lot of guys will use RED loctite to keep the jam nuts from coming loose.
Old Apr 28, 2014 | 02:58 AM
Yeah we heated it up with MAPP gas and sucker wouldn't budge.
Crazy how corrosion can weld stuff together
