Rock krawler 2.5" max travel system
The rock krawler joint uses a pretty short shank and I doubt there is enough threads to make the arms long enough to re-center with the addition of an adjustable upper set. This is pretty well know and have seen several threads about have to "upgrade" the lower arms when adding adjustable uppers to re-center the axle.
If you swapped that joint out to say a currie Johnny joint or the metal cloak rod end then you should have plenty of extra threads to extend the lenght of the link. Note that rock krawler uses a 1" shank on the rod ends vs 1.25" used by others makeing that a weak point.
I would like to see Rock Krawler comment on that information. Since you can buy the lower arms separately which only have a single SKU, which ones are you getting? I believe the MID arm system is all the same whether you buy it in a kit or separate. You can easily add the other arms in after. They are all adjustable arms...they're not fixed lengths... Im currently installing a 2.5" X-Factor and before i had a 3.5" flex on my TJ that i added the uppers arms in after the fact and it was just fine!
Space
Space
RK02022 - Rear Lower Control Arms
* Requires Adjustable Rear Uppers
RK02064 - Rear Lower Control Arms
* For use with Factory Rear Uppers
Copied and pasted from RK's site.
High Clearance Rear Lower Control Arms
Take a look at the tab that says "How to order - SKU's"
Here are the SKU's.
So this issue only pertains to the 2.5" Max Travel and the 3.5" Flex kit.
You would always be able to sell the lowers to recoupe some of the money.
