Rock Krawler 3.5 Xfactor long arm lift 4dr
For those of you running this lift, what shocks did you go with and what are the part numbers that I need to order front and rear shocks? I heard the bilstiens were a bit stiff and that I should look at the Fox racing shocks. The difficulty in ordering is that Fox sells by what lift you have. The Rock Krawler long arm lifts relocate the lower shock mounts 2 inches higher. Is that for front and rear as do you just order 2" shorter shocks than Fox recommends?
You might want to consider the RRD Shocks by Rock Krawler. We run these on our JK and have set up many other customers with these shocks. Everyone that has them loves them, we are able to come up with custom valving numbers to make them ride the way you want them to.
PM us if you would like pricing on anything.
