Rock Krawler experts?
A guy in my Jeep club has a new 3.5 mid arm flex system for sale. It's brand new, has 5100 shocks and is for a 4 door. The problem is I have a 2door, I looked at their website and didn't see different springs, just wanna make sure it will be ok before I jump on it. Thanks!
Keep in mind that the lift will be typically an inch higher on your 2dr vs the 4dr. If you're lacking heavy mods front and rear then you may pick up a little more lift.
Sent from my Droid4 and Jkfreaks.com
They are the same kit as in will bolt in the same. Your statement is correct because the 2 door is not as heavy as the 4 door so you will achieve a little bit higher lift height.
