Rock Krawler or OME Lift ?
I just put in the Rock Krawler 2.5" stock mod lift this past weekend.
I looked at both kits closely when I was researching lifts, and both get great reviews. I went with Rock Krawler because it's made in the US and it seems to be easy to expand if I want to make some changes later on (although the same is probably true for the OME).
I noticed minor differences between the basic kits in terms of what's included and what's extra, but the basic Rock Krawler kit seemed to be a little more comprehensive in that it included an adjustable from track bar and disconnects (the basic OME was springs and shocks). Some vendors offer package deals for the OME, though, so again, it's probably a wash. I got Bilstein shocks and lower control arms in addition to the basic Rock Krawler kit (which doesn't include shocks, although they recommend some).
But like everyone else has said, you can't go wrong with either one.
I run the OME and have been very happy with it. And I am (was) researching a new lift for the JKU I have coming and sure read a lot of good things about both. I'm thinking you can't go wrong with either.
I see you are running a Terraflex now,,, thinking of switching,,, ?
Previous owner put the tereflex kit on and it is just a spacer lift.
I prefer a real lift and want to maximize articulation.
What I have works, but my rig is not a Mall Crawler.
Looking for something that is civil to drive, and articulates well, without going to huge expense of steering or driveshaft mods.
ROCK KRAWLER 2.5 Max Travel Kit includes...
System Includes:
(2) long travel progressive rate front coil springs,
double adjustable front track bar made from 1.5” solid alloy steel,
(2) high clearance adjustable front lower control arms made of 1.625” solid alloy steel,
adjustable front sway bar disconnects,
(2) long travel linear rear coil springs, precision welded rear track bar relocation bracket made from ¼” thick laser cut steel,
(2) high clearance adjustable rear lower control arms made of 1.625” solid alloy steel,
front and rear long travel stainless steel brake lines,
extended rear sway bar links,
hardware and detailed instructions
Rock Krawler RRD Racing Shocks
NO REAR TRAC BAR, JUST A RELOCATE BRACKET
NO SPRING RETAINER
NO BUMP STOPS
Approx $1,800.
____________________________________________
OLD MAN EMU 2.5 Long Travel Kit/package...
OME JK long travel kit includes
4 springs (with choice of soft medium hard) ,
4 twin tube OME shocks ,
front and rear JKS adjustable trac bars ,
JKS rear spring retainer ,
front and rear Teraflex bumpstops ,
front and rear sway bar links.
Tereflex F & R lower control arms.
Approx $2,000.
System Includes:
NO SPRING RETAINER
NO BUMP STOPS
Approx $1,800.
Approx $2,000.
It seems that the OME kit has more stuff, but RK's trackbar relocation bracket is tough as hell so i would trust that.
The coil spring retainers are cheap and so are bumpstops if you get them at the right place.
I do believe that if you go with the hard springs it will give you more of a lift, but the RK gives you the RRD shocks with their kit, which seem to be very good shocks, versus OME twin tube, which are known to both articulate great and ride well.
I guess it comes to the fact of spending an extra $200, or buying an American made product.
This might sound cheesy, but i "Rock Krawler" rolls off the tongue nice than "Old Man Emu"
Gotta be worth something.
