Sponsored by:
Sponsored by:
Rock Krawler Suspension Open Tech Line for JK Forum Members
Old 11-05-2018, 08:29 AM
  #871
resharp001's Avatar
Received 1,826 Likes on 1,596 Posts
Originally Posted by jsukey
That question might be better suited for Teraflex since you are still running their control arms...I’m assuming. All lift kits are not created equal.
I'd submit that the length of the control arm depends more on the brand of spring than the arm itself. Different manufacturer springs will net various differences in lift. Regardless of brand of arm, the length will be determined by lift height. I have RK springs, but I think I struggled to find their recommended lengths when I installed adjustable arms further down the road. I just used recommend lengths found in the instructions for a different brand spring that commonly nets more lift (like RK springs do) than the stated number. It will get you close enough to start, and then might need to tweak them based on alignment specs.
with adjusting height you're looking at caster changes which an alignment shop can fix with adjustable arms.
Not sure other parts of the country, but around my area this is not included in the basic cost of an alignment. They will do it for an extra charge though. Just be prepared that it could cost more.
If you're handy, you can easily take the alignment specs and tweak the front upper arms a bit shorter or longer to account for raising or lowering your caster once back at home.
jsukey (11-05-2018)
Old 11-06-2018, 08:19 AM
  #872
Former Vendor
Rock Krawler Suspension's Avatar
Originally Posted by Bxjk
How’s it going? I just installed 3.5 rock krawler coils. Changing from 2.5 teraflex.
My question is I have the new coils in and I’m getting that flighty feeling up front at highway speeds. I also have adjustable control arms all around. By any chance do you know what length the control arms should be at top and bottom front and rear for your coil springs. And should I adjust or have my Jeep professionally aligned ? Will they adjust control arms ?
Thanks
Sorry for the delay, all of our techs were at SEMA and just getting back into the office today. What you are describing is typically indicative of low caster. You can find our recommended starting lengths for each lift height in our online instructions HERE starting at page 5.
Adam C
Old 11-08-2018, 07:42 AM
  #873
Bxjk's Avatar
Appreciate all the info. You guys are the best
Old 11-11-2018, 02:57 PM
  #874
11BlackJKUR's Avatar
Default Rock krawler 1.5” max travel upgrade to X factor
I have a 1.5” max travel kit and I want to upgrade to a 1.5” X factor and I’d like to slide the axle back the one inch to gain extra clearance on the pinch seam. What would I have to buy to make the upgrade thanks in advance
Old 11-13-2018, 02:09 PM
  #875
Former Vendor
What generation is the Max Travel you have? In the rear, does yours have upper OR lower arms? Current production includes uppers but, in the past we made it with lowers.
Adam C
Old 11-14-2018, 12:41 PM
  #876
My kit came with lower rear arms
Old 11-15-2018, 06:22 AM
  #877
Former Vendor
You'd be looking at adding:
Front upper arms RK02020
Rear Upper arms RK02028B
Rear lower arms (if you want that 1" of axle movement rearward) RK02022
Rear spring perches RK03866
Rear Track Bar RK02026B
Rear adjustable sway bar links RK05185
Adam C
Old 11-15-2018, 06:34 AM
  #878
Wow I thought the rear arms my kit came with were adjustable? I’m assuming the spring perches are weld on?
Can you recommend a place to buy the spring perches I only seen the 3” and the 6”.
thanks
Old 11-15-2018, 06:44 AM
  #879
TheDirtman's Avatar
Thats called an "upgradeable" arm. You upgrade to a longer one and throw the other away.
Its due to the inherant design flaw of the the RK short arms and their joint design to fit those arms. You are looking at a lot of jack to save from doing some minor trimming. I would serious look into alternatives vs buying stuff from a company that touts "upgradeable" and then requires you to buy components you already bought.
Old 11-15-2018, 06:50 AM
  #880
Yeah it does sound like a lot for an upgrade and it is bs I have to buy at least two hundred dollar control arms twice.
Quick Reply: Rock Krawler Suspension Open Tech Line for JK Forum Members
