Rock Krawler Suspension Open Tech Line for JK Forum Members
#871
If you're handy, you can easily take the alignment specs and tweak the front upper arms a bit shorter or longer to account for raising or lowering your caster once back at home.
jsukey (11-05-2018)
#872
Former Vendor
How’s it going? I just installed 3.5 rock krawler coils. Changing from 2.5 teraflex.
My question is I have the new coils in and I’m getting that flighty feeling up front at highway speeds. I also have adjustable control arms all around. By any chance do you know what length the control arms should be at top and bottom front and rear for your coil springs. And should I adjust or have my Jeep professionally aligned ? Will they adjust control arms ?
Thanks
Thanks
Adam C
#874
Rock krawler 1.5” max travel upgrade to X factor
I have a 1.5” max travel kit and I want to upgrade to a 1.5” X factor and I’d like to slide the axle back the one inch to gain extra clearance on the pinch seam. What would I have to buy to make the upgrade thanks in advance
#875
Former Vendor
Adam C
#877
Former Vendor
You'd be looking at adding:
Front upper arms RK02020
Rear Upper arms RK02028B
Rear lower arms (if you want that 1" of axle movement rearward) RK02022
Rear spring perches RK03866
Rear Track Bar RK02026B
Rear adjustable sway bar links RK05185
Adam C
Adam C
#878
Wow I thought the rear arms my kit came with were adjustable? I’m assuming the spring perches are weld on?
Can you recommend a place to buy the spring perches I only seen the 3” and the 6”.
thanks
thanks
#879
Thats called an "upgradeable" arm. You upgrade to a longer one and throw the other away.
Its due to the inherant design flaw of the the RK short arms and their joint design to fit those arms. You are looking at a lot of jack to save from doing some minor trimming. I would serious look into alternatives vs buying stuff from a company that touts "upgradeable" and then requires you to buy components you already bought.
