Rock Krawler Tie Rod and Falcon Stabilizer - Will it work?
Old Aug 7, 2018 | 04:03 PM
TheGrateOz's Avatar
Default Rock Krawler Tie Rod and Falcon Stabilizer - Will it work?
I have a Rock Krawler Off Road Pro Tie Rod. Has anyone used a Falcon Stabilizer with it? The tie rod has a diameter of 1.75" and the larger Falcon stabilizer have a 1 5/8" clamp.
Is there a way to make it work? If not, what stabilizer do you use?
Thanks!
Old Aug 8, 2018 | 04:17 AM
Canvas's Avatar
Veteran: Navy
Contact Rock Krawler and get their stabilizer mount. I have the same tie rod but run Fox stabilizer with out an issue.
Old Aug 8, 2018 | 05:44 AM
CJCCJ4 JK's Avatar
You can get ahold of tera flex and get a bigger clamp for that stabilizer. I just did the same thing. I called teraflex and it cost $23.
Old Aug 9, 2018 | 06:52 PM
TheGrateOz's Avatar
Thanks, I called and they said I could get the 1 5/8" clamp but not a 1 3/4. I guess that i a few months out still... =(
Old Aug 14, 2018 | 09:09 AM
cranbiz's Avatar
Barnes Off Road sells a stabilizer bracket for a 1.75" tie rod. I think it's around $35
Old Aug 14, 2018 | 06:59 PM
SullivanM08's Avatar
Check out the synergy one too I accidentally ordered the one with smaller mount on my fox ats and just got there's for the 1.75 yeti
Old Aug 14, 2018 | 07:05 PM
https://www.quadratec.com/products/1...RoCCeoQAvD_BwE
I had to use a different bolt than what it came with for fox ats the absorber rod would have contacted the bolt, just keep that in mind
Old Aug 21, 2018 | 07:13 AM
Rock Krawler Suspension's Avatar
Former Vendor
Carolina Metal Masters makes a clamp for our tie rods for Fox ATS, Falsons etc
